pcv question
  • Thread starter Thread starter 68keyblr
  • Start date Start date Aug 23, 2007
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 23, 2007
  • Aug 23, 2007
I'm trying to hook up all of the vacuum hoses to the '93 cobra intake that I bought.
There's a fitting underneath the upper intake on the driver's side toward the back. I know the PCV hose from the lower intake connects to one side of the fitting...but where does the hose on other side of the fitting go to?
cenok is family
1,409
69
79
Norman, Ok
Aug 23, 2007
  • Aug 23, 2007
the T fitting on the back right corner (when standing in front of car, looking towards the rear) of the intake? i capped one of the sides off.
88mouse
630
Mooresville nc
Aug 23, 2007
  • Aug 23, 2007
one goes to the vac tree.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 23, 2007
  • Aug 23, 2007
So one end goes to PCV on lower intake and the other end goes to vac tree? Can I cap off the vac tree end like cenok?
One other question - the heater tubes that run down the manifold by the passenger side valve cover has 2 hose outlets that used to go to the old EGR spacer - one to the front and one to the back.
The Cobra intake has only the front one - nothing in the back. Where do I hook up the back hose? Or can I just cap them off ?
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 24, 2007
  • Aug 24, 2007
Correction - only one small nipple on the heater tube that goes to the front of the EGR spacer. The lower manifold has a fitting at the passenger side rear that connects to a hose that goes to the back of the EGR spacer.
The new cobra lower had a plug in place of the fitting on the lower manifold.
So can I just plug these fittings and remove the hoses to the EGR ? What's the downside?
88mouse
630
Mooresville nc
Aug 24, 2007
  • Aug 24, 2007
Yea you can plug off that vac line. But then you won't have vac going to any thing that runs off that vac tree. As far as the other to egr spacer hoses i pluged mine. Will help keep the air intake temp. down.
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
