  • SN95 4.6L Mustang Tech
Pcv Questions
  • Thread starter Thread starter bhuff30
  • Start date Start date Jul 19, 2012
bhuff30
6,037
35
129
Olathe KS
Jul 19, 2012
  • Jul 19, 2012
Today, I noticed more smoke than the occasional tiny puff on take off. In fact, it was a consistent large puff of smoke on take off, I suspected the stupid hot weather increasing oil temps and viscosity, but now I suspect a PVC issue. There is a breather on the drivers side which vents to the air intake tube (after the MAF). The line flows freely, but if I blow into the line, no air flows into or out of the valve cover. It seems to be blocked somewhere internal to the valve cover. Is that normal?
The rest of the PVC system seems normal. The PCV still rattles and all the lines are clear.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jul 19, 2012
  • Jul 19, 2012
Are referring to the plastic pipe/tube that goes from the drivers valve cover to the Cold Air Intake? That tube should clear of any obstruction of any kind.
Clayton302
79
Hurricane Utah
Jul 19, 2012
  • Jul 19, 2012
If your blowing into the cam cover you shouldn't be able to blow though it very much, its job is release crank pressure. Try capping it on the intake side for a minute to see if the smoke goes away. Put it back after though.
bhuff30
6,037
35
129
Olathe KS
Jul 20, 2012
  • Jul 20, 2012
Yeah, the tube that goes from the intake to the drivers side valve cover. The tube is clear, but it feels like there is an obstruction inside the valve cover? There isn't a PCV type valve internal or something, like that that can be replaced?
The smoke comes from the drivers side. Ideally, there should be some negative pressure in the valve cover to reduce oil leakage past the valve stem seals at idle. It would be closer to equal pressure so less oil passes by those seals.
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 8:00 PM
Blackhawkxx
J
PCV system help for S/C
  • jay99914
  • Feb 16, 2025
SN95 4.6L Mustang Tech Sep 26, 2026
AngryH58
A
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
