PCV System
  • Thread starter Thread starter blue92lx
  • Start date Start date Aug 6, 2006
blue92lx
14
  • Aug 6, 2006
I've been having a couple issues with my PCV valve and grommet. First off, I have a trick flow intake with a Vortech Making 14lbs of Boost (just incase those will affect the PCV operation.). I'm using a new PCV Valve and new Grommet as well.
The Problem is the PCV Grommet kept slipping out and was BARELY holding onto the intake manifold. As soon as oil vapor would touch it you could barely touch the grommet with your finger and it would slip right out without a hitch. So what I did was applied a very thin line of RTV to the lip of the grommet with my finger to hold it in.
What happened then is that the PCV Valve did the same thing. It would slip right out. So again, I put a very thin line of RTV around the PCV Valve with my finger to hold it onto the Grommet.
So I went out today and test drove it again and it hit about 12 psi and seemed to run fine. When I got back and checked it you can see that the valve is trying to push free, although it did not pop out this time.
What would be causing this to happen? Would this be caused by the boost pressurizing the vaccum lines? I don't think I have excessive blow by, I'm going to check tomorrow morning, but there's never been oil on the plugs and never been any smoke coming out visibly (I've only pulled the pcv valve out and checked at idle however) from the pcv hole at idle.
blue92lx
14
  • Aug 6, 2006
A small update on my setup because I was reading the PCV system sticky on here.
I DO have a breather AND the PCV system hooked up. NO TB/VC hose, both ends are plugged.
I've never heard that having a breather AND PCV system work against each other. I'm kind of at a stand still here. Also, if I have a Breather AND a PCV system, shouldn't that alleviate crankcase pressure better at WOT since it has more places to go? I'm pretty much just confused now.
HISSIN50
34
129
Aug 7, 2006
  • Aug 7, 2006
The issue is: with a mix of both methods, there's an unmetered air issue, which can lead to leanness. Now with that sick combo, I am sure your tune takes care of it (read: I bet a little unmetered air isnt making a huge difference in things).
For one-bar of boost, I personally would probably just run breathers. It does sound like blowby is doing the PCV removal from the intake (remember, that PCV valve only flows one direction).
The guys big into forced induction will have more/better ideas.
Good luck.
vristang
4,933
101
124
Seattle
Aug 7, 2006
  • Aug 7, 2006
There are a couple of threads in the Tech Thread Index (listed in a sticky at the top of this forum) which should answer some of your questions.
I have no experience with boost (yet)
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
M
Resolved PCV Tube and Valve Cover Breather Hole Locations
  • MDrisc
  • Sep 11, 2024
Fox 5.0 Mustang Tech Sep 22, 2024
MDrisc
M
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
Engine Genius installed oil filler above rocker arm…
  • afjLX
  • Mar 27, 2025
Fox 5.0 Mustang Tech Mar 29, 2025
nicholase
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
