Hi, this will be my first post to the forum I have appreciated all the info from other threads. I've got a 67 coupe with a 289, C-4, Hedman headers, Edelbrock(carb, intake manifold and cam). Just about finished with a total engine rebuild, repainted the engine well, replaced all steering components and all front suspension parts. My first question is, how important is the PCV valve? Is there a problem with just putting a small filter cap in it's place? Does it make a mess that way or change the performance in any way? My second question is, I bought a Ford racing mini hi-torque starter. If I'm reading the directions correctly, it says to hook up the large wire from the starter to the post nearest the shock tower on the starter relay along with the battery starter cable. And the small black wire gets hooked to the post nearest the battery. Does this sound right? My notes said I took the battery + cable off of the side closest to the battery when I was using a OEM starter.
Any help would be appreciated.
