pcv valve concerns
It's not really the valve that's bad, per se. It's more that the design of the overall system is not particularly spectacular. Ford's fix was to use a new valve cover with slightly modified interior baffles.
But yes, your car is in the 'potential problem' zone. That's not to say that every 99-00 V6 experiences difficulty. Some people never notice it. For some it's a real problem.
You can fix it if you prefer, but unless you've noticed an issue, there's really no harm in leaving it as is.
Edit: I have a 2000 myself, and I've never noticed any kind of knock. I fixed it anyway for the hell of it.
Neither. Put breathers on the valve covers, and capped off the upper intake the TB tube.
Just keep your stock hoses around in case you ever need an e-test. You won't pass it if they notice you've deleted your PCV.
dont u get a smell when the car is stopped and you have norm ac on or the heater? or dont your valve covers get covered w/ oil?
No oil on the valve covers. It doesn't generally breathe huge quantities of liquid oil, just the odd bit of vapor. That doesn't stick around.
I smell it occassionally. It's worse when you have the AC on, but I rarely use my AC anyway. I prefer to just roll down the windows anyway.
