PCV Valve Vacuum Port
  • Thread starter Thread starter warmdye
  • Start date Start date Mar 9, 2004
warmdye
482
Out in the Desert
Mar 9, 2004
  • Mar 9, 2004
Does it matter which port on the upper manifold the pcv valve hose is connected too? I want to connect it to the T port on the corner of the manifold instead of one of the ports in the middle of the manifold.
Whats up with this setup he has it connected to both ports:
http://forums.stangnet.com/attachment.php?attachmentid=15926
Also, i am trying to clean up and get rid of any unused vacuum lines on the manifold. When i removed my upper manifold I notice a vacuum line connected to the T port on the corner of the manifold and the other end is connected to one of the vacuum ports on the center of the manifold. I have heard this line is for balancing the vacuum between the two ports but it really doesn't make sense to me. Is this line neccessary?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 9, 2004
  • Mar 9, 2004
Just don't connect the PVC valve to the same port as the vacuum tree.
If you do, there is an opportunity for oil vapor to make it's way into all the vacuum operated control systems on the car, like the brake booster.
warmdye
482
Out in the Desert
Mar 9, 2004
  • Mar 9, 2004
I have elimated my vacuum tree. I don't use any of the ports on it except the brake booster and I have that connect directly to the manifold. But thanks for the info.
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
