  • SN95 4.6L Mustang Tech
PCV Valve
  • Thread starter Thread starter vvzer0incvv
  • Start date Start date May 17, 2004
V
vvzer0incvv
133
Carol Stream, IL
May 17, 2004
  • May 17, 2004
Ok guys i'm getting ready to change the fuel filter and also the pcv valves on my 96 gt. I purchased the parts from autozone and they both don't look right. The fuel filter is fat and short, don't know it if will fit in the same holder for the old filter. The pcv valves have connections for two hoses on them that are each a quarter of the size of the hoses that are on the original pcv valves. Any ideas guys? THanks
Jeff
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
May 17, 2004
  • May 17, 2004
post part numbers , maybe someone can double check them for you
V
vvzer0incvv
133
Carol Stream, IL
May 17, 2004
  • May 17, 2004
PCV: PCV271 (The brand is DEUTSCH for both)
Fuel Filter: FF679
Thanks guys
Cars&Guitars
41
Colorado
May 17, 2004
  • May 17, 2004
I'm not positive but I think they're wrong. I know I had to get the PCV and fuel filter from Parts America. The stupid autozone computer even had the wrong plug information. The plugs were full threaded (?). The guy was like it has to be right because its in the computer. Well dufus, your computer is wrong.
T
TARZAN
446
Philly MS
May 17, 2004
  • May 17, 2004
I'd go to a parts house (carquest) etc....
As far as the 2 places for hoses go, there PCV valve should come with a small lip (for lack of a better word) to put the plug into the top hose, and make it mout.
-Will
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
May 17, 2004
  • May 17, 2004
i crossed the numbers and they seem to be correct for a 96 GT and the other guy is right on the pcv , its a universal replacement basically so it should have a small plastic piece the plugs the top hole up
stimmler
248
Japan
May 17, 2004
  • May 17, 2004
Even the replacement ford PCV valve looks exactly the same as the autozone one. I thought the same and got one from ford. It looks different because its a generic replacement for several others. I also didn't use the fuel filter because it looked cheap and so I ordered a ford replacement also.
  • Gulftown980x
  • Jul 29, 2026
squeak93
Which is the correct PCV valve
  • Trogdor
  • Mar 18, 2025
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 18, 2025
Mustang5L5
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
