PCV Valve
little tip, and this has been mentioned in other posts but it helps even if you know where it is, and that is to find the pcv hose under the drivers side of the intake manifold, and follow it around till you get to the valve and pull it out, i've found this easier because it helps keep your hands away from all the freeking vacuum lines and hoses.....
Ryan, if the valve is coked up or the spring is broken, it can lead to high crankcase pressure, which looks for the next path of least resistance (seals). Or the valve can simply be popped out of the intake when pressure builds, and you end up with a big ol' vac leak.
Get a Motorcraft PCV valve, screen and grommet for about 20 bucks and then forget it for a couple years.
Good luck.
Make sure to clean the screen and watch out for the grommet (#2 in the figure). Its a PITA to get out and likes to leak. Use a little black RTV when you put it back in to insure a good seal...RTV the block side not the interior where the PCV valve goes in. :D
