  • SN95 4.6L Mustang Tech
PCV valve
  • Thread starter Thread starter 2003_GT
  • Start date Start date Apr 16, 2009
2003_GT
69
Santa Fe, NM
Apr 16, 2009
  • Apr 16, 2009
It wont budge im trieng to take it off to replace it and it wont come off, any tips
squeak93
2,327
405
164
Joplin, Missouri
Apr 16, 2009
  • Apr 16, 2009
Try turning it counter clockwise.
Or just pull harder...
2003_GT
69
Santa Fe, NM
Apr 16, 2009
  • Apr 16, 2009
I tried turning it left and right and it wont move WTF
squeak93
2,327
405
164
Joplin, Missouri
Apr 16, 2009
  • Apr 16, 2009
Which side? the pass side just slides in, the d/s should twist out.
Flghtmstr1
572
Springfield, PA
Apr 17, 2009
  • Apr 17, 2009
On your car, only the passenger's side has an actual PCV; the driver's side thing on the valve cover is just a breather. There is no reason to take the driver's side breather off, and the passenger's side PCV should slide out pretty easily.
flstang65
1,484
135
94
SE Georgia
Apr 17, 2009
  • Apr 17, 2009
don't some of stangs not even come with pcv valves?
2003_GT
69
Santa Fe, NM
Apr 17, 2009
  • Apr 17, 2009
Yeah iv been trying to take the passeger side one out but it wont move not even a little bit
squeak93
2,327
405
164
Joplin, Missouri
Apr 17, 2009
  • Apr 17, 2009
Pull the cam cover and see whats up. Maybe someone glue it in to keep from blowing it out...
trinity_gt
3,125
81
99
Canada
Apr 17, 2009
  • Apr 17, 2009
The PCV, at least on mine, has a couple of notches that engage the valvecover mating part to ensure a tight seal and that the valve doesn't back out. The valve does remove with a counterclockwise twist but you might take a gander at the notches that I talked about on the valve itself to see if you can assist the removal process by lifting tabs or pushing down as you turn etc. You don't want to snap the plastic body of the thing in the process...
evolucion311
236
May 4, 2009
#10
  • May 4, 2009
  • #10
anyone have a part number for the counterclockwise twist out PCV valve?
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
  • Gulftown980x
  • Jul 29, 2026
squeak93
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
