  • SN95 4.6L Mustang Tech
PCV
  • Thread starter Thread starter JRS02GT
  • Start date Start date Nov 9, 2006
JRS02GT
39
Ruskin, Fl.
Nov 9, 2006
  • Nov 9, 2006
I was cleaning my engine the other day & noticed some oil on the engine's right valve cover. It seemed odd since I know I didn't spill any when I changed it. I cleaned it and drove it for a few days. I checked it & it had a little oil there again. It looks like it is seeping out of the PCV valve where it connects to the hose that runs to the upper plenum. The car has also been idling poorly lately too. I am figuring that the two problems are connected. I hav never noticed a PCV system pulling oil into itself before. I thought it just sucked up excess gasses. There is enough coming out to thinly coat that valve cover & get a little in the tube that runs to the plenum. It is only that one side, the valve on the opposite cylinder head is not doing it. Is that normal?
BurningRubber
1,865
24
58
Nov 9, 2006
  • Nov 9, 2006
Sounds like its time to change it. How many miles are on it? It only costs a few bucks and takes less than 5 mins to swap.
JRS02GT
39
Ruskin, Fl.
Nov 9, 2006
  • Nov 9, 2006
It shouldn't be. The car only has 28k on it.
sgarlic
3,085
Nov 9, 2006
  • Nov 9, 2006
The PCV system sucks crankcase vapors back to the plenum to be burned. Crankcase vapors contain oil. Either the little gromet in the valve cover is ripped, or the PCV valve isn't fully seated (or screwed if you have a later model.)
RandyStinchcomb
1,159
Randallstown, Md
Nov 10, 2006
  • Nov 10, 2006
well, 25k to 30k is the recommended change interval and make sure you get OEM and not one from a parts store, it does make a difference.
JRS02GT
39
Ruskin, Fl.
Nov 10, 2006
  • Nov 10, 2006
Ok. If I just ask for replacement pcv valves, does it come with the rubber fittings and all?
JRS02GT
39
Ruskin, Fl.
Nov 10, 2006
  • Nov 10, 2006
And what do they sell for?
RandyStinchcomb
1,159
Randallstown, Md
Nov 10, 2006
  • Nov 10, 2006
Ford part # is 2X4Z-6A666-AA and sells for @$9.00 and I seem to think there was a TSB on the grommets for leaking. I'll look into it and see what I can findout
JRS02GT
39
Ruskin, Fl.
Nov 10, 2006
  • Nov 10, 2006
Thanks for the help! Please let me know if you find a tsb.
JRS02GT
39
Ruskin, Fl.
Nov 27, 2006
#10
  • Nov 27, 2006
  • #10
Hey Randy: I tried to get the part that you recommended, but my local dealers don't stock it. They gave me part # D9ZZ6A666A. It is different from the original part in that it has 2 tubes on the top and both are considerably smaller than the tube it needs to fit with on the stock setup. Is D9ZZ6A666A even the correct part at all? I don't trust either of the local dealers and was hoping you might be able to help.
twogts4us
4,188
12
79
Dunedin, FL
Nov 27, 2006
#11
  • Nov 27, 2006
  • #11
I ended up putting a small hose clamp on mine to prevent it from leaking. The hose (that connects to the PCV valve) is worn/loose.
RandyStinchcomb
1,159
Randallstown, Md
Nov 27, 2006
#12
  • Nov 27, 2006
  • #12
yeah the "D9ZZ" is a push-in one and yours should be a 1/4 twist/turn and lock in place. the one they sold you will work inna' pinch, just don't use that plastic 2 port adapter that came wth it.
Matt's 03 GT
Orange County
Nov 27, 2006
#13
  • Nov 27, 2006
  • #13
Randy:
I have the same problem with the local dealer. I actually have the "Heated" Pcv valve. I refuse to pay $40.00 for the heated valve (I live in Southern California...the land of 70 degree winters). Is there an alternate part number?
I received the D9ZZ Valve and the outlet pipe diameter is significantly smaller than the outlet on the heated valve (like 1/4" opposed to 1/2"). I appreciate the help!!
Matt :SNSign:
RandyStinchcomb
1,159
Randallstown, Md
Nov 27, 2006
#14
  • Nov 27, 2006
  • #14
Matt's 03 GT said:
Randy:
Matt :SNSign:
yeah, you can also use the 2X4Z-6A666-AA which is @$9.00
Matt's 03 GT
Orange County
Nov 27, 2006
#15
  • Nov 27, 2006
  • #15
Randy:
What do I do with the unused wire? It would be unsightly to just leave it...no?
Thanks for your help, you are a great resource.
Matt
RandyStinchcomb
1,159
Randallstown, Md
Nov 27, 2006
#16
  • Nov 27, 2006
  • #16
Matt's 03 GT said:
Randy:
Matt
just tape it back and you'll be fine
Matt's 03 GT
Orange County
Nov 27, 2006
#17
  • Nov 27, 2006
  • #17
Thanks,
Matt
JRS02GT
39
Ruskin, Fl.
Nov 27, 2006
#18
  • Nov 27, 2006
  • #18
Thanks for the reply. I will see if I can get the single port cap off the original and use that. If not, I will just buy one. Is the rubber grommett that matches up with it supposed to be a huge pain in the butt to get in? I started trying to get it in place on Saturday and fiddled with it throughout the weekend. It is still not in. I am almost convinced it is the wrong part.
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
