Performance problems
  • Thread starter Thread starter CPB00GT
  • Start date Start date Feb 20, 2004
C
CPB00GT
531
Florida
Feb 20, 2004
  • Feb 20, 2004
I recently installed my off road Mac H-pipe, and had a shop weld the middle together after I installed it. The first problem is I don't think the pipes were pushed together enough cause the driver side sometimes rubs against part of the undercarriage and is somewhat annoying. My check engine light now comes on once in awhile during acceleration. And the most annoying thing is the car still misses right after 4K when it is warmed up and your getting on it hard. I already gave the car a complete tune up in an attempt to fix this. Any suggestions to these annoyances?
SmockDoiley
1,591
San Diego, CA
Feb 21, 2004
  • Feb 21, 2004
What is your timing set at? Also, the distributor itself or the module could be crappin out on you. Do you have a friend that could loan you a dizzy to test out.
C
clarkjr
716
NC
Feb 21, 2004
  • Feb 21, 2004
As far as the pipe hitting the floor pan, it could be partially due to worn motor mounts allowing too much movement (the engine will lift the driver's side which will bring the pipe upward). The shop should have adjusted the fit before bolting everything together and now that the H is welded, you have lost much of that ability. You can try taking it back to them and see what they can do. As far as the check eng. light, you need to read the codes.
C
CPB00GT
531
Florida
Feb 22, 2004
  • Feb 22, 2004
Todat I installed a new ignition module, coil, and reset the timing to 14*. The car runs like a champ! I also installed a water temperature guage, cause the stock one doesn't work anymore. It stays steady at right above 180*. My only problem right now is to try to adjust the H pipe from hitting that bracket on the frame rail. I'm not sure sure what the problem was with the missing but one of these fixed it. I probably should have done one thing at a time. The loose hatch gets fixed today!
SmockDoiley
1,591
San Diego, CA
Feb 22, 2004
  • Feb 22, 2004
Did I call the module or what. I would have said coil too but you said you already gave it a complete tune up. Sweet, well the exhaust problem you can live with for now, but at least the major engine problem is gone now.
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
