i personally run Autolite 764 coppers
Bingo. Don't go spending $8 a plug for something you do not need. The Denso plugs have been proven to keep good spark under high boost. The Bosch quad-platinums are a very hot plug and are really intended for cars burning a little oil... Autolite plugs = teh win. Even in LT1 and LS1's on the Dyno, Autolite plugs show a higher horsepower gain than any other plug. NGK's are good plugs, but Autolites are easier to find, cheaper to buy and perform just as well if not better.bdcardinal said:unless you have a blower or are running a lot of spray, there isnt a need for an exotic plug.
Kilgore Trout said:Motorcraft AGSF-32C at the Ford Parts counter... Or Autolite 764s at AutoZone. Yep yep...
Don't just say they are bad for the 4.6 explain whyDarkhorse845 said:I would go with Motorcraft platinums or Autolite 764's.
Whatever you get don't get the bosch plugs because
they are horrible for the 4.6L engine.
Kronos said:Don't just say they are bad for the 4.6 explain why![]()
Yes 32 is the stock heat range and the C on the end means copper.John324 said:Are those the copper ones, same heat range as the stock platinums?
