- Nov 11, 2005
- 317
- 0
- 0
Eh, another problem with the stang (not surprised). Ok I believe that a faulty pertronix flame coil is the culprit of my latest snafu. I came across a similar question from this site: MGB: Possible Pertronix Problems
MY QUESTION is how can I identify whether or not I have a 1.5 or 3 ohm coil? Or does it not matter because the coil should be receiving 3 ohms irregardless? I plan to make a trip to the local parts store to rent a multimeter and test my coil to see if its still working. Thanks!
*Just in case I wasnt clear* I just want to make sure which ohm coil I have so I know if the 1.5 or 3 so when I measure if its lower than what it should be operating at.
. Then a few days later after driving about 2 minutes again it started again
. Thought it was a carb issue since it only happened while the car was idling (ran smooth above 1000 rpm), but I had recently dunked the carb in a gallon of parts cleaner. I even blew out the idle screw ports in case any trash in the lines clogged it up. The symptoms sounded like an ignition miss and shortly after researching on some random site, bingo.
