In order to change everything over on my ignition system to electrical, what Petronix parts do i need?
thanks
thanks
69Mach351 said:I went with their coil and the ignition system that replaces the points (pnx-1281 if you want to see it on summit) The only downside is i have no limiter now so I will probably get 6al for that
I have considered this but I am planning on spraying a little while down the road, wouldnt mind a low rev limiter while i break in my motor as well. Everything is upgraded to the point where it should be able to rev pretty high and i dont want to chance it65fastback2+2 said:ive always considered floating the valves to be my limiter
mcbride66coupe said:In order to change everything over on my ignition system to electrical, what Petronix parts do i need?
thanks
Yes, sometimes you can, there range is like 9 to 16 or something. but after all of the problems ive heard about with undervoltage to the ignitor, i decided it would be better to do it correctly. And the flamethrower coil does require 12volts because it has an internal resistorMax Power said:Pertronix I can run on less than 12 volts.
