  • SN95 4.6L Mustang Tech
PI Heads
  • Thread starter Thread starter Black Stang 97
  • Start date Start date Dec 5, 2004
Black Stang 97
the guy on top of me is funny
Nov 11, 2004
483
Los Angeles, CA
Dec 5, 2004
  • Dec 5, 2004
What are PI heads?? or PI intake?? can anyone give me a lil info on this, and around how much are they running for??
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 5, 2004
  • Dec 5, 2004
PI heads are the cylinder heads that ford switched to for the 99-04 mustang GTs. they are also found on F150s and 01+ panther chassis cars. they have a square inlet port with larger valves and a smaller combustion chamber. the PI intake is the intake made to match the airflow characteristics of the PI heads. i got my heads used for $170 on Ebay, but you can buy them new for about $400 a piece from various places. the intake is about $200. on a 96-98 GT there is a 50-70 hp increase from switching to the PI heads and intake. however the compression ratio is increased to about 10.5:1 so using a blower is almost out of hte question. the camshafts used in the PI heads are also different.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 5, 2004
  • Dec 5, 2004
although bdcardinal did a great job explaining, do a search there is alot of info on here.
Black Stang 97
Nov 11, 2004
483
Los Angeles, CA
Dec 5, 2004
  • Dec 5, 2004
So what do i have to buy in order to have a good setup?? the PI Heads, the PI intake, do i also have to change the camshaft??
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 5, 2004
  • Dec 5, 2004
when you order the PI heads you get the PI cams with them. all you need to install them are a complete set of tools, the heads, intake, gaskets and new headbolts.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 5, 2004
  • Dec 5, 2004
http://www.enthusedproductions.com/headswap/
take a look, good info
53BigDog
2,331
Palm Harbor, FL
Dec 5, 2004
  • Dec 5, 2004
Very informative thanks Tom
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
J
Used PI intake what to check for
  • jay99914
  • Oct 29, 2024
SN95 4.6L Mustang Tech Nov 4, 2024
jay99914
J
