I'm doing the PI intake swap on my 97 GT. Do I have to tap my intake for the second temp sensor or can I just leave that unplugged? What will the results be if I leave it unplugged? Thanks for any help and suggestions.
your sensor has to be plugged in. the fan will run all the time and your airconditioner won't work. does youe intake have aluminum water crossover? if so drill and tap. if not I extended it to my heater core and put a metal "tee" in line. i put it on the intake tubing(output) not the return.
The temp sensor for the gauge is on the passanger side, the one that goes in the aluminum crossover is for the EEC. You can put the EEC one on the left if you stretch the wiring harness out far enough as you need that one in. The gauge one you can leave out, but you may as well do it right and get the crossover tapped as it's tough to do later when the intake is on the engine.
You can extend the wires and install it at the unused bung on the lower drivers side of the block. It has a cap that can be removed and the sensor screws directly in. Should be right behind the motor mount.
