  • SN95 4.6L Mustang Tech
PI Intake
  • Thread starter Thread starter Black Stang 97
  • Start date Start date Dec 5, 2004
Black Stang 97
the guy on top of me is funny
Nov 11, 2004
483
Los Angeles, CA
Dec 5, 2004
  • Dec 5, 2004
Do i have to change the PI intake and the PI heads at the same time??
Blev
1,295
So. Cal. V-Town
Dec 5, 2004
  • Dec 5, 2004
If you are putting PI heads on, yes. I can't imagine putting time and money into heads and not doing the intake.
If you're talking about just doing the intake now and doing heads later, That's what I'm doing. I have had the intake on for a while now and finally got my heads. So that was just one less thing I needed to buy for the swap.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 5, 2004
  • Dec 5, 2004
yes, i mean why wouldn't you?
there are 96-98GT adapter plates for a PI intake for non PI heads. but it's a waste of money. might as well get it all done at the same time
Sick96Stang
621
Gilbert, Arizona
Dec 5, 2004
  • Dec 5, 2004
well some people want the extra power now instead of saving up for the PI heads as well. Not to mention when u get teh PI heads you are still running he same compression so you will have to buy some low compression pistons to run boost after you do the heads. You could just keep saying "oh well why dont you just save up for this before you do this" it could go on for along time.
Blev
1,295
So. Cal. V-Town
Dec 5, 2004
  • Dec 5, 2004
I sorta agree with you because I bought the plates. I lost torque due to the drop in compression from the 1 inch thickness of the plate. At least that's my theory. HOWEVER....I did notice it pulled alot harder up top and I'm pretty sure some of that can be attributed to the smoother transition from the PI intake to the NON-PI heads. If I had to do it over I think I would do it exactly the same. Only reason is because I know I had a good seal right from the get go. I know alot of people have had great success without the plates, but I felt better knowing they were there. But, the heads are in my garage, my vacation is less then 2 weeks away and the heads will be in.
Black Stang 97
Nov 11, 2004
483
Los Angeles, CA
Dec 5, 2004
  • Dec 5, 2004
So i can just put the PI intake and then later on get the PI heads?? Would there be alot better performance with just the PI intake???
Blev
1,295
So. Cal. V-Town
Dec 5, 2004
  • Dec 5, 2004
Yes. You'll notice it pulls alot harder in the higher RPM's. Typical gains, depending on other mods, have gone from 15 - 20 hp. Some may say more, but I have only seen dyno sheets reflecting 15 - 20.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 5, 2004
  • Dec 5, 2004
Black Stang 97 do you have the PI intake already? and what year GT did it come off of?
Blev - give is an update when you start doing it
misterb
42
  • Dec 5, 2004
For a 2002 GT, where can I find the heads & intake and related parts, gaskets, etc?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 5, 2004
#10
  • Dec 5, 2004
  • #10
if you are specifiacally asking about a 2002 GT wanting to put on PI heads, walk to your car, left the hood and stare at the PI heads and intake that are already on.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 5, 2004
#11
  • Dec 5, 2004
  • #11
Black Stang 97
Nov 11, 2004
483
Los Angeles, CA
Dec 6, 2004
#12
  • Dec 6, 2004
  • #12
I dont have it yet, i wanted to ask you guys b4 i bought it, so the stock throttle body and the stock plenum will juss mount right over the PI intake?? no modifications needed??
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 6, 2004
#13
  • Dec 6, 2004
  • #13
it'll work great, only mod you will do is to get a T fitting for the 2 temp sensors for the coolant.
CanadaStang
2,093
Mb
Dec 6, 2004
#14
  • Dec 6, 2004
  • #14
You are better off looking for the newer PI intake with the aluminum cross over, and tapping it for the 2nd sensor, or you can reuse your cross over if yours no longer has the solid plastic intake.
misterb
42
#15
  • Dec 6, 2004
  • #15
Smart ass..
I just got the GT (my "Track Car" is a 450 HP Firebird) and read about CNC ported "PI" heads.. I thought these were the same heads.
mr. jones1
102
NJ
Apr 2, 2005
#16
  • Apr 2, 2005
  • #16
try my plates $100.00
sold on e-bay
go to my site for details
www.unitedmajority.com
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Apr 2, 2005
#17
  • Apr 2, 2005
  • #17
you have them for 150 on your web site
mr. jones1
102
NJ
Apr 2, 2005
#18
  • Apr 2, 2005
  • #18
I fixed that-sorry, originally I could not find a reasonable manufacturer.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
SN95 4.6L Mustang Tech Jun 12, 2025
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
