While a tune is always good, if you do it right you can get around without doing it. I did the swap and I know that you will need, if you don't get the intake with the motor you have to get the pi intake that has a hole drilled into it for you temp sensor we have two and the 2000+ cars have one. Your coil packs brackets are gonna need to be swaped and the passneger side one doesn't really fit exactly right but it will fit and be stable enough to drive. Ummm lets see there is a few more things but not much. When I did mine I started some threads just do a search and you can see what I went through. It was so worth it in the long run. I can add boost later with out too much worry like I would with a PI head swap.
