94-98 Mustang with 2000 cobra R wheels on it.....preferably white. I'm thinking about making my 95 R wheels into my track wheels and running the 18s on the street.
Thanks!
Thanks!
I am another IRS satisfied person... woot... tell em brianEvil Ash said:Great to hear about the IRS. I may have to consider doing that conversion one day.
You could always just do what my friend is doing and build a track car from scratch. He was going to go the hybrid route but found that working around the factory parts was too difficult. The hardest part really is the body. He's trying to make it not only street legal but to look like a "Daytona"? spec racer.
It's a mid engine with a ZZ4 350 with fuel injection, a 911 transaxle and willwood brakes. Should weigh in at 2,000lbs.
Toddzilla said:Well, you have a nicely sorted rear suspension as it is, so I'm not sure how worth it you'd think it is.
The 03 setup is definitely the best as it already has 355s, stronger halfshafts, IRS brace, and relocated inner tie-rod ends. But a 99-01 would be fine also, and get you most of the way there. As far as the diff goes, I don't think you're putting out enough power to really worry too much about getting a 99 vs a 03 IRS. If you were drag racing, maybe, but not as it is now.
Going from the stockish solid axle to the IRS I noticed the following.
1) The car hooks MUCH better in 1st gear. I'm willing to bet I could knock a tenth or two off my 60' times.
2) The car rides MUCH better than it did with the solid axle.
3) It handles better in every way. Better turn in, much better corner exit, much more predictable.
4) As a negative, it does wheel hop some, but nothing bad at all.
5) It also adds 85 lbs to the rear over a stock setup, but it might be a wash compared to a TA/PHB setup.
Toddzilla said:Ash, I didn't have an MM rear suspension. I just had bilsteins, MM swaybar, BBK LCAs (ick), and eibach springs.
I now have 03 cobra IRS, MM subframe bushings, 03 cobra bilsteins, H&R race springs.
Toddzilla said:Those are some SERIOUSLY ******* up tires!!! My god, that's scary.
Do you have any idea what kind of price range he is looking for?
Evil Ash said:Interesting. Because over stock I got all the benefits you are saying with about half the weight penalty and not too bad of a ride.
I'd be curious to see/follow the car on track.
Well at least for as long as I could since you'd probably beat me to turn one by 10 seconds or more.
we'll see about that after i get the proper rear and front spings onviperos said:yeah, Kalin loves his IRS... around the north-405 exit for BM... he goes smoothly, and stays on the road, whereas I kinda hop around the corner... however... to keep your rear-end on the ground, you need to keep your front end on the ground telling your car where to goright Kalin?
