I picked up an 88 SD 302. Took the block today and sanded the gaskets off, tapped the bolt holes. Degreased, pressure sprayed and wd-40'd it. Everything looks pretty good, for the most part. The question however is about the cylinder walls. A couple of the walls have a slight discoloration to them and have VERY VERY slight perpendicular scratches. The crosshatched look great. Thanks in advance
