  • 1994 - 1995 Specific Tech
Picked up some 3.73's today.
  • Thread starter Thread starter 1105
  • Start date Start date Jan 22, 2004
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Jan 22, 2004
  • Jan 22, 2004
Today my dad ordered some gears from the Ford dealership down the road and I picked them up. It ended up being $2 more than ordering them online from gefracing.com so I paid $157 in the end. What do geats normall come with? I got some shims and a pinion nut with mine. Will I need a pinion spacer for my rearend?
And what tooth speedo gear will I need?
94Blue302GT
704
Chicago
Jan 22, 2004
  • Jan 22, 2004
Well, what gear do you have in there right now? And you will need to know what drive gear you have on the transmission. D&D has a good table for that stuff, i think it's at ddperformance.com
1105
May 3, 2003
3,841
Daytona Bch, FL
Jan 22, 2004
  • Jan 22, 2004
Right now I have the stock 2.73's and stock transmission.
Ryan Paterick
943
  • Jan 22, 2004
Have you changed your tire size in the rear, or is it still stock?
Reason I asked is that I changed my tire size in the rear and put new gears from my 3:08's to the 3:73's also.
I was told that getting a new http://www.brothersperformance.com/shop/mustang/brospeedcal.html
would solve my speedometer issues.
1105
May 3, 2003
3,841
Daytona Bch, FL
Jan 22, 2004
  • Jan 22, 2004
I have nitto 275/40/17's on the rear of my car... not sure how much taller they are than stock. Thanks for the link but that thing is a little expencive for me right now.
Joes95GT
3,132
Delaware
Jan 22, 2004
  • Jan 22, 2004
A speedcal is probably your best bet since you have changed tire/wheel sizes. For the gear swap it would be a good idea to pick up a new pinion bearing and pinion seal. Also, since you were having the problems with the stock differential, you should pick up a new clutch packs from Ford and rebuild the diff too.
Joe
red94fiveo
1,269
Wichita, KS
Jan 22, 2004
  • Jan 22, 2004
Order a speedo gear from cjponyparts or somewhere if your tight for cash. your speedo will still be off, but not nearly as much. I got mine for $16-17 and I did the same thing as you (2.73's to 3.73's), my speedo is off maybe 4-5 mph on the highway, nothing I can't live with.
GTPhreak
5,505
Rowlett, TEXAS
Jan 22, 2004
  • Jan 22, 2004
275/40-17 is the same overall diameter as stock
Ryan Paterick
943
  • Jan 22, 2004
Yeah, bit expensive. I guess you have to order it over the phone also. They program it too figure out your before setup and then they put in the new setup.
I would get the speedo gear in your case. I think its the 23tooth gear also.
1105
May 3, 2003
3,841
Daytona Bch, FL
Jan 22, 2004
#10
  • Jan 22, 2004
  • #10
Thanks for the site. I'm not too worried about if its off a little bit but dont want it to be way off. I had my dad order a new clutch pack for my car from the ford dealership and I'll have all the parts tonight (minus the speedo gear) to start the install. Hope to install them tomorrow after school or on saturday.
Joes95GT
3,132
Delaware
Jan 22, 2004
#11
  • Jan 22, 2004
  • #11
Did you get a bottle of friction modifier for the posi?
Joe
1105
May 3, 2003
3,841
Daytona Bch, FL
Jan 22, 2004
#12
  • Jan 22, 2004
  • #12
I think the shop will have some.. if not we'll order it when we go to install the gears.
OinkAodeOink
3,026
Daytona bch, Florida
Jan 22, 2004
#13
  • Jan 22, 2004
  • #13
good deal zach.. Now your going to put those Nittos to good use!
You'll love the low end pull, im telling ya...
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
  • Locked
SOLD Maximum Motorsports MMTR-2 Bumpsteer Kit - 1979 - 1993 Mustang
  • AeroCoupe
  • Apr 18, 2025
Fox Body Mustangs For Sale (1979-93) Aug 5, 2026
AeroCoupe
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
