Pilot Bearing Help
  • Thread starter Thread starter dagara
  • Start date Start date Dec 18, 2006
D
dagara
  • Dec 18, 2006
Hello all,
I have a 302 '65 mustang that i bought a year ago. i decided to swap in a t5 for the automatic that was already in. I pulled out the old tranny and put on the new block plate and flywheel, but when i went to install the pilot bearing that came with the kit it wouldnt fit. I looked up the code on the engine and it turns out it is a 302 out of a 74 torino, so i bought the pilot bearing for that year engine but it was slightly too big. Both pilot bearings will only go in a fraction of an inch even with coercion from a hammer.
Any ideas? Not sure if its the wrong crank shaft, and so i would have to match up the pilot bearing to that crank shaft. Is there a way to buy a pilot bearing by size rather than by year? Or can i have the pilot bearing machined down a little bit? I can't wait to get her back on the road. Thank you for any help you can offer,
Robby
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Dec 19, 2006
  • Dec 19, 2006
The bearings should fit.
My only guess is that not having a bearing in place for 40+ years has allowed for the buildup of dirt and other surface corrosion. Have you tried cleaning the bearing mating surface with some sand paper or emery cloth? I ended up using a sanding roll on my dremel to lightly clean up the area.
F
FullRace
41
  • Dec 19, 2006
Freeze the bearing, then pop it in. Make sure the crank is clean as well.
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
9
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
