pilot bearing replacement?
  • Thread starter Thread starter a_turbo_stang
  • Start date Start date Apr 14, 2004
a_turbo_stang
346
Cincinnati Ohio
Apr 14, 2004
  • Apr 14, 2004
Hey will I need a bearing puller tool thingy to pull the pilot bearing out of my 5.0? I know they are pressed in or something like that.
dastang2
2,020
tx
Apr 14, 2004
  • Apr 14, 2004
i have been told to fill the inside with grease and get a bolt that is just small enought to barely fit in the hole and knock it in a few times then keep packing it full of grease and continue. what happens is the grease has no where to go so it start to push the bearing out.
93 teal terror
971
62
69
Durham N.C.
Apr 14, 2004
  • Apr 14, 2004
sometimes that works sometimes it doesnt....if the pilot bearing was lightly greased around the outside when installed it will probably come out that way, however it may be siezed and that method wont work. You'd be better off renting a puller and a slide hammer at autozone just in case
a_turbo_stang
346
Cincinnati Ohio
Apr 14, 2004
  • Apr 14, 2004
Ok I will give it a shot. Thanks!
a_turbo_stang
346
Cincinnati Ohio
Apr 14, 2004
  • Apr 14, 2004
Didn't know autozone had pullers. I will have to see about getting one from them. My luck it will be rented out. lol
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
Engine Pilot bearing
  • twohawks777@cox
  • Jul 22, 2025
Fox 5.0 Mustang Tech Aug 7, 2025
twohawks777@cox
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Ignition Question
  • WantAn88GT
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
WantAn88GT
