PimpXS and wacky AFR
fasterthangas
288
91
38
Phoenix
I have a genuine mystery here. I'm using the PIMPXS in SD. Car was tuned and running fine.
Cold start shows AFR in the 13.0 range and as it idles; the AFR eventually goes to 18.0.
Fuel flow and pressure appear to be fine.
Plugs look great. I changed them for good measure.
During steady state cruise I slowly roll into the throttle and the AFR jumps to 16.0 or a tad higher causing a stumble.
When stabbing the throttle, there's a momentary lean spike and then it goes pig rich to 10.0
AFR is all over the place.
If anyone wants to view datalogs; I can email them.
Thanks!
How long have you had that wideband sensor ? They need to be re calibrated in free air every few months. Make sure there are no exhaust leaks before the sensor.
That's always a possibility. I haven't come across anything suspicious as far as a vacuum leak.
Except this:
Do you still have EGR or other solenoids still in play, that might cause intermittent leaks?
Except this:
I should have worded it differently. I haven't seen anything suspicious under the hood. I looked over the vacuum lines and catch can plumbing the other day. I didn't see anything suspicious. I didn't test the lower intake though. All smog equipment is removed.
I should have worded it differently. I haven't seen anything suspicious under the hood. I looked over the vacuum lines and catch can plumbing the other day. I didn't see anything suspicious. I didn't text the lower intake though. All smog equipment is removed.
I'm going to move this over to [General Talk] to get some more opinions.
I'm inclined to believe that your issue may be physical/mechanical versus a tuning issue.
If I'm wrong, we can always move it back.
Reactions: fasterthangas
