pins & bushings
  • Thread starter Thread starter whiteyford0212
  • Start date Start date Oct 19, 2005
W
whiteyford0212
24
  • Oct 19, 2005
i gotta 93 mustang and the door is sagging and is a a bitch to shut..so i got a new set of pins & bushings..any of you guys have any idea how to do it?
ive heard u have to get a whole new hinge?
vristang
4,933
101
124
Seattle
Oct 19, 2005
  • Oct 19, 2005
I used the hinge kit last summer on the 2.3L. It worked great.
The only recommendation I can give is to be patient. It can be tough getting everthing to line up right. Might be easier if you use a jack to support the door?
jason
W
whiteyford0212
24
  • Oct 19, 2005
so how did u get the old ones out?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 19, 2005
  • Oct 19, 2005
Hinge pin & bushing kits are available at many auto parts stores. Or see http://www.texasmustang.com/ or http://www.mustang-unl.com/lmparts.htm. Usually less than $7 for the kit with one pin & 2 bushings.
Th hard part is to get the old pin out. Some were spot welded in, others were hammered so that the end mushroomed. Either way, it takes a grinder or cutter bit in a drill or Dremel tool to cut the pin or grind off the weld. Once it is off, tap the pin out with a hammer. Only remove one pin at a time so that you don't have the full weight of the door to manage. I highly recommend that you have a helper standing by to hold the door.
Once the old pin is out, lower the door and tap out the old bushings. Put the new bushings in and have the helper lift the door in place so that you can slide the new pin in. It may have to go in differently from the way it came out. That's OK, as long as you put the cotter pin in the hinge pin.
OOOPS!!! The important thing to remember is that the hinge pin isn't supposed to move once you are finished. If it does, then you will end up like me - the pin moved, it wore the door hinge instead of the replaceable bushings. Now in order to fix it right, I have to remove the whole thing again and drill out the hinge to the same size as the bushing and use 2 sets of bushings in each hinge rather than one set.
The fix for the OOOPs was very time consuming and if you aren't up to some very interesting machine work, do it right so you won't have to do it again. I fixed the OOOps but I had $43 worth of drill bit and specialized reamer plus pulling the fender off to fix it.
RMODEL65
313
brunswick ga
Oct 19, 2005
  • Oct 19, 2005
pins
the most accurate way is to remove the front fender (and the easiest way to get to the alignment bolts for hinges although this way takes time removing the fender you will be glad u did) remove fender this will expose the hinges u can either unbolt the hinges from car make sure to protect the rocker panel with towels as to not chip the paint and put door on a work bench or on a towel on ground or leave them in place make sure to support the door with a floor jack as doors are very heavy esp mustang doors because they are long, and cut the pins in half so that u can drive them out with use a cut off wheel or jigsaw,sawzall etc and grind any welds if any. once old pins are removed put in new bushings dont forget to grease them reinstall pins with the other half of the hinge make sure not to put other half on backwards or u will end up starting over with dissa. put door back up near position using the floor jack and start the bolts when lining up the door make sure u line up the door to the rear quarter panel first then line up the front fender to the door also rember to replace the striker bushing as most cars this age are usally missing these and will make door alignment nearly impossible without them and ur doors will probaly rattle ifr u dont hope this info helps
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Oct 19, 2005
  • Oct 19, 2005
I used an SA-5 style carbide bur and air grinder. Using the bur I cut the pin right in half and then pounded out the two pcs out as well as the old bushings...takes some time and you need the right tools, but quite easy when you have everything together.
vristang
4,933
101
124
Seattle
Oct 20, 2005
  • Oct 20, 2005
I guess I'm luckier than I thought!
I just used a long punch die to push the pins out. The only thing I had trouble with was getting all the holes/bushings/pin to line back up for the install.
Also, I just pulled one pin at a time so that I did not have to hold the entire door up. Did the job by myself in a couple of hours (1 door). Actually, I did it twice in that time because the first time I put a bushing in wrong.
Maybe my 87 LX is odd, but it seemed pretty straight forward.
jason
rd
3,316
63
109
Ocean Springs MS
Oct 20, 2005
  • Oct 20, 2005
Suggestions:
Get a helper to hold the door, and also support the rear end of the door with blocks of wood while you do this.
The early Foxes have an e-clip on the pins and you can drive them out. However, the top pin has to be driven up, and may hit and scratch the door. The official shop procedure is to cut or drill it. Some had a pilot hole to drill.
Later ones have the ends swedged and have to be cut.
If you are lucky, the new bushings and pins will restore door alignment. With a range of wrenches and such, you can adjust the hinges on the body on the car, through the opening between the fender and door, but it is tedious.
Do not let the door twist when you have one pin out.
D
AOD TV cable replacement bushing - loose pin?
  • DuluthFoxbody
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2026
DuluthFoxbody
D
Paint and Body Door Sag Help...
  • robw13
  • May 1, 2025
Fox 5.0 Mustang Tech May 8, 2025
robw13
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Thursday at 10:40 AM
AeroCoupe
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
