pinto potential?
4bangen
143
Ok I just got this pinto, it is setup for a 289/302 but came with a 351w I am trying to deside what motor to put in there. It has a c4 and a mustang 8"rear end. I dont know wither to make the 351 fit or sell it for a 302, or I could drop the 2.3t I have in storage with a holset on it. help me deside.
slow95gt said:
Well it sounds like your set on putting a 2.3 in there. Good luck with the swap and the build!!!
Josh
at this moment Im leaning more tward the 351w mostly becouse the sound of a cammed v8 gives me goose bumps. But we will see how I feel tomorrow thats about as often as I change my mind:rolleyes:
I think trying to build a turbo 302 setup into a Pinto would be an exercise in self-torture and eventually self-destruction once you had a 500hp/500lb-ft V8 in a 2300lb car. I saw one at the drags with a healthy NA 302 doing low 11s.
I plan on getting a pre-'74 Pinto(smog exempt) and doing a TC swap. The SVO is my semi-restoration car, so a Pinto would get the MegaSquirt, FMIC, Holset.....
65ShelbyClone said:
I think trying to build a turbo 302 setup into a Pinto would be an exercise in self-torture .
the car already had a 289 in it once, so a v8 is a simple drop in bolt up prosedure, Im a lazy person by nature so a v8 will most likely go back in. Then I will make sure it is the loudest meanest scaryest pinto in town!(to make it scary all I have to do is disconect the brakelights:p )
well I have some bad news. As of last friday I was layed off from my job. That mean s no pinto for me. I was bummed at first but than started thinking about the fact that when i gat a new job I can consentrate on on the t-bird and the buick. So its not that bad.
