My 02 GT is stored for the winter and once every two weeks I start her up and run her for 20-minutes or so to circulate the oil in the engine and trans, recharge the battery and mostly, to make me feel better to at least hear her run while not being able to drive her.
Anyway, some may recall my GT suffers from quite the piston slap when it's cold. A rather annoying light rattle from the engine at very light (almost no) load between 1500 and 3000RPM, give or take, when the engine is cold. It usually goes away after a couple of minutes of driving but it's disconcerting nonetheless. Today I let the car run for a half-hour as I got caught up doing some other stuff. Before I shut her down, I rev it a bit; 2000, 3000, 4000 with a few stabs at the pedal. I noticed that if I hold the engine at, say, 3000 and rev it slowly & smoothly to 4500 or so I can hear a definite, if faint, noise that sounds like the cold piston slap even after the engine has been running for a half-hour and it's hot.
Am I being paranoid? Are the pistons that are so loose fitting Ford had to put a SSB (# 15934) out on them, still loose at normal temp and I'm just still hearing them? The car has 27,000KMs on it (less than 17000 miles) and the engine gets good mileage and makes good power so it seems otherwise healthy. Only mods are a K&N FIPK and March piggyback UDPs.
Who else has a noisy 2V? Do I need to start saving for a VT shortblock? Should I rattle some cages at Ford to get this looked at as a possible warranty engine?
Thank you. So it's not just me that thinks their GT has a diesel like sound to it at idle.
