  • SN95 4.6L Mustang Tech
Piston question
  • Thread starter Thread starter Performance Red
  • Start date Start date Nov 27, 2005
P
Performance Red
75
  • Nov 27, 2005
I'm in the process of building up a 2001 2v motor and am wondering what all it would take to put flat top pistons in, I assume the pistons and rings, but would they work with the factory connecting rods? Would they bolt right up or would i need to get the engine balanced. Thanks
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 27, 2005
  • Nov 27, 2005
Do you plan to blow or turbo? If so, flat tops will be a problem as the compression will be too high.
If you are doing this level of work to your engine, you are going to want to SCRAP the factory connecting rods so do not worry if they will bolt up. They ARE the weakest link
white99gt
4,649
stockbridge,Ga(near atlanta)
Nov 27, 2005
  • Nov 27, 2005
Pistons and rings,but like trout said.DONT keep the rods.Stock rods are the weaklink.
Any time you go internal,check the bore ,possibly may have to be bored over,and always rebalance the bottomend.
P
Performance Red
75
  • Nov 27, 2005
I plan on making a pretty much all out n/a motor, so it would be reccommended that I replace the pistons and connecting rods with forged pieces, can I leave the stock crank in for the time being? I dont have the budget to put an all forged rotating assembly in, but would like to switch over to flat top pistons.
white99gt
4,649
Nov 27, 2005
  • Nov 27, 2005
Stock crank is fine.But rods and pistons are a must.
Just swapping pistons in a mod motor is not a good thing.Do it right and only do it once.
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Nov 27, 2005
  • Nov 27, 2005
it would be foolish to have to have to tear apart the motor again later down the road. (too much time/money wasted).
68
  • Nov 27, 2005
Last thing you want is to throw a rod like my buddy did. Get you some new rods if you upgrade pistons. That's my .02 cents.
69Rcode_Mach1
1,473
Salt Lake City, Utah
Nov 27, 2005
  • Nov 27, 2005
Again definitely get some new rods with it. And add some ARP hardware too, then you can spin away and have peace of mind.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Nov 27, 2005
  • Nov 27, 2005
like everyone else said just swap out everything. Just dont go FI if you are going with flat tops the CR will be to high, if you do plan on going FI just get dished
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
G
Turning a 4.6 into a 5.4
  • Green mustang
  • Jun 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2025
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
