Piston Ring Questions for a 302...
  • Thread starter Thread starter POWER302
  • Start date Start date Dec 9, 2005
P
POWER302
427
IL
Dec 9, 2005
  • Dec 9, 2005
I want to put a new set of rings in my motor while its apart. Its a standard bore 87 5.0 HO with the factory forged pistons.. What are my factory rings sizes? 1/16 or 5/64? Also what is a good set of rings for a HCI 302 w/ a wet shot that has future plans for boost "I was looking at speed pros"? I want them to be file fits also.. What is a good ring gap that will be decent for nitrous or boost? And Last what is the difference between low and high tension rings I have heard about?
Thanks
Eric
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 9, 2005
  • Dec 9, 2005
Thanks
Eric
should be metric rings sizes I think should have 4 rings instead of the older engines only had 3 if I am remembering correctly
Rick 91GT
Mustang Master
95
99
PA
Dec 9, 2005
  • Dec 9, 2005
The Speed-Pro's will be fine, plasma moly tops is what I would look for.
I would go .022 top and .024-.026 second ring...this will help the rings stay stable and prevent flutter, it will also help get the heat out inbetween the rings.
3 rings total top, second and oil ring (oil ring is 3 pcs) I can't remember the ring size off the top of my head I do more aftermarket pistons then stock.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 9, 2005
  • Dec 9, 2005
speed pro number on factory piston I think is E458K
1.5mm rings and 4.0mm oil ring
P
POWER302
427
IL
Dec 9, 2005
  • Dec 9, 2005
Well. Im wanting to order a set of rings asap.. Where can I find out what my stock rings thicknesses are.
Rick 91GT
Mustang Master
95
99
PA
Dec 9, 2005
  • Dec 9, 2005
I'll look when I get to my shop in a bit
P
POWER302
427
IL
Dec 9, 2005
  • Dec 9, 2005
Thanks
Rick 91GT
Mustang Master
95
99
PA
Dec 9, 2005
  • Dec 9, 2005
I just grabbed a stock piston and it was a 1.5mm top and second and a 4mm oil ring.
BlackBaer5.0
100
  • Dec 9, 2005
the problem is !some! cars with Hypueretic (sp?) pistons and other earlier models are standard sized ring widths and the forged pistons in the 91 on up cars were metric ..
just my $0.02
Rick 91GT
Mustang Master
95
99
PA
Dec 9, 2005
#10
  • Dec 9, 2005
  • #10
just my $0.02
Yeah I've had 5/64, 5/64, 3/16 ring combos as well... the forged piston I pulled was from a 88 302 Mustang, it would be best to check yours with a pair of calipers though.
P
POWER302
427
IL
Dec 9, 2005
#11
  • Dec 9, 2005
  • #11
So we really have no idea what my ring thicknesses are.. I would like to order some rings before I pulled the rods and pistons out.
Rick 91GT
Mustang Master
95
99
PA
Dec 9, 2005
#12
  • Dec 9, 2005
  • #12
Most parts stores can get the rings next day or even same, it will take you atleast that long to get the old pistons and everything else clean.
Are you having the block honed?
Make sure the ring grooves are very clean before re-installing.
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
L
Whats a safe limits to take this engine to?
  • LCATGA
  • Sep 3, 2024
2005 - 2014 S-197 Mustang -General/Talk- Sep 5, 2024
89ripper
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
