Engine Pistons For 302
Hey everyone I got the motor pulled and started taking it apart and I found the number 8 piston head was broken in pieces(yay me).
So anyways I was wondering if there is any good piston heads for the a 302 block that'll match with GT40p heads? And is the Ford Performance E303 camshaft any good?(The teeth are chipped on mine).
Also if I decide to bore the cylinders to a 306 should I just buy the Summit rebuild kit for 300 that comes with the oil pump and new piston heads for the .030 upgrade?
I'm taking the block to get honed and machined and all that good stuff soon.
Also screw mechanics who break things. They stripped my pickup tube into my oil pump and broke the oil pump :mad:
Putting a 331 under a set of GT40p heads is money not well spent. If this is a naturally aspirated engine, get a set of SpeedPro .030 over pistons, they are like $200 for a set of 8 on ebay all day long. Turn the crank if necessary, new bearings, resize the rods, bore and hone the block. Try and find a Steeda #19 or #18 cam (#18 if you are willing to put a chip on the computer, #19 if you don't). Much better for those heads.
Kurt
