Ok i was going to go witht he trickflow Track heat..but now the shop i use went thru some more options...Let me know what you think?...Ok i have the GT40 heads there done now...5 angle valve job mild porting and mild skim cut...new stainless exhaust valve,teflon coated valve seals...Trick flow valve springs...set at 125-130 seat pressure..Ok im going to go with a Track heat intake...I want to get a good blower cam maybe a comp or Anderson cam..or maybe even a custom cam...He is pulling the motor...and were going to have a custom torque convertor made for the AOD...3.73's...It has a paxton supercharger It should be making 7-8 psi...42's 255lph pump..UPR powerpipe, and DBX 95MM Maf...so do you think this will be good?..So can i make over 300 rwhp with this combo do you think i can run 12's ???
