i accidentally bought AP25 autolite platinum spark plugs and was wondering if these are better or worse than regular, copper spark plugs.
srothfuss said:Worse! (at least for our mustangs)
The resistivity of Platinum is much greater than copper and with a remote coil ignition system you will get a crappy running engine in most cases. I say return them and get the 'cheap' copper ones. You and your motor will be much happier.
he's right! remember newer cars nowadays come with coil-on-plug ignition system compared to ours that's using a remote coil, so newer ignition system has higher voltage output and require the use of platinum for its higher resistance..srothfuss said:Worse! (at least for our mustangs)
QDRHRSE said:Really? I never use the platnums myself but once again- really? I think we need to discuss this. I can't see how this is true. Almost every car Ford sells comes with double platnum plugs these days so I wonder about the validity of this statement. I'm not sure though. That's why we need to discuss it. Smarter people- lets get moving on this!!!!! Mike Yount......
vristang said:I like this topic so how bout if I throw a wrench in the whole conversation and bring up higher voltage coils. Does running an MSD coil/ignition make platinum plugs more feasible?
HISSIN50 said:J- I certainly would think so. It helps overcome the lack of conductivity (vs copper).
We are speaking relatively though, as the TFI ignition is quite a strong OEM ignition (given when it came out) IMHO. But I personally like your line of thinking.
I may be way out of touch with reality but aren't Fram and Autolite basically the same company. I have seen first hand the horrendous quality of a Fram oil filter, so I am not too sure about Autolite. Call it guilt by association.BaXTeR3221 said:Autolites are cheap and they are the best plug, makes the choice simple![]()
This is just the kind of info I was hoping forCurse said:MSD does not recommend you use platinum plugs with their ignition systems.
Mustang5L5 said:Coppers are cheaper, and changing plugs is not that difficult on a 5.0.
vristang said:I may be way out of touch with reality but aren't Fram and Autolite basically the same company. I have seen first hand the horrendous quality of a Fram oil filter, so I am not too sure about Autolite. Call it guilt by association.
8950HO said:..... Platinum plugs were developed for lazy slobs ...
.... or for guys that want to avoid changing plugs in the 3.8 Firechicken as loooooonngg as possible vristang said:I may be way out of touch with reality but aren't Fram and Autolite basically the same company. I have seen first hand the horrendous quality of a Fram oil filter, so I am not too sure about Autolite. Call it guilt by association.
