I just brought my car to a shop to have them check the vibration I've been having since I did H/C/I. Just to give a quick description of the problem, I had everything enginewise installed in my signature. It ran fine for 2 days, then after I did a burn out, the whole car started vibrating like crazy whenever I rev the engine. Clutch in or out, rolling or not, in gear or not etc. Well, after replacing the balancer, all clutch components with a new flywheel, checked the energy suspension mounts etc, it still vibrates. Well, they called me and said there is a little bit of play in the crankshaft and I have a slight rocker tick. They also said there might be other issues like the flywheel being off balance, even though its new, which I know is possible. I have a few questions. Can I have them replace the crankshaft and bearings and be ok as long as everything else inside is ok? Would anything else need replaced? What should this job cost? Could anything else be damaged? I didn't drive the car hard after the vibration started and I only drove it maybe 50 miles after that to get home and to the shop. Any advice would help! Thanks.
