- Feb 11, 2007
- 33
- 0
- 0
I bleed the brakes and my buddy stated that we didn't have to bleed the master cylinder. Is that right? I have power brakes, disk up front and drums in the rear. For some reason, the brakes have to be pressed harder than hard for the car to come to a rolling stop. I got my muffler changed and the individual there said you may want to look at the vacuum lines, "They may not be getting info vacuum for the booster to work correctly". I have never heard of that. So I took pictures of the lines of how the vacuum lines are setup on the booster.
Here is the booster with two lines coming from it! (I know about the bent bolt, so no one needs to point that out ha,ha,ha)
The bottom line goes into this
The second line seems to go into the manifold (i think its the manifold) and gets split again.
The lines gets split and goes across the width of the car and goes into the other side of the fender inner side and connects.
If anyone can figure this out or tell me how to correct this it would be greatful.
