Please Help! 89 GT backfiring
  • Thread starter Thread starter blue306
  • Start date Start date Feb 8, 2006
blue306
9
  • Feb 8, 2006
My 89 GT is currently backfiring. Everytime when I attempt to floor the gas pedal it starts to make those popping noise from the exhaust and at the same time the engine starts to hestiage and miss. This usually occurs when I accelerate hard above 3000-3500 rpm but when I drive normal, the car seems to run fine. I can't seem to figure out what's the problem. I 've checked the vacuum hoses, EGR, BAP Sensor, cap and rotor, timing, and I took out a few plugs,and they all looked fine. What else can it be??? The GT have about 180k with a 5 speed and the engine is mostly stock except a few basic mods like 65mm throttle body, shorty headers, pro chamber, catback....
curtisimo81
33
pensacola,fl
Feb 8, 2006
  • Feb 8, 2006
have you checked for clogged cats? if you even have them, i have seen many of cars do that because of the catalatic converters being clogged
blue306
9
  • Feb 8, 2006
Thanks for replying. I'm using a mac pro chamber so that're no cats clogging issue and I checked the exhaust for leaks and there is none.
craigwhite89gt
181
Cecil County Maryland
Feb 8, 2006
  • Feb 8, 2006
When u took the cap off did u try shaking the shaft to the distributor to see if there is play? Mine wasnt backfiring but it would hesistate like crazy ...
blue306
9
  • Feb 8, 2006
Great idea, I will check it tomorrow to see if there's any play in it. Thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 8, 2006
  • Feb 8, 2006
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
blue306
9
  • Feb 10, 2006
I've tried but no codes came out.
blue306
9
  • Feb 10, 2006
Tried shaking it but it was not loose.
F
frcefedlx
184
  • Feb 10, 2006
I just got my car back from the body shop after it got hit and found some small adjustments needed to be made. But my car did the same thing and I found that my fuel pressure was really low for whatever reason wich leads to the question of how is your fuel delivery eg. maybe clogged injectors or fuel pressure bleeding down constantly, maybe your fuel pressure regulator is bad. I know with my car it back fired when i got on it and then bang, some times on decel but mainly under load. I just brought my fuel pressure back up and problem gone. I dont know if this helps but maybe worth a look.
blue306
9
#10
  • Mar 2, 2006
  • #10
Car is finally fixed. It was the ignition module at fault. Hope this will help if other stang's owners have the same backfiring problem.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • brandyn200
  • Jun 20, 2026
AeroCoupe
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
