Please help, baffled.....
  • Thread starter Thread starter 89CopCoupe
  • Start date Start date May 11, 2004
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
May 11, 2004
  • May 11, 2004
For the life of me, I can't figure out how to tighten or remove the cigarette lighter in the console of my 89 Coupe, please help
Does anyone have a solution to stop the e-brake handle from rattling due to exhaust tones at around 2K rpms
Also my clutch pedal/mechanism makes two quick click sounds when I'm releasing it, anyone know what that typically is
Any help is greatly appreciated, thanks.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 11, 2004
  • May 11, 2004
dont know about the cigarette lighter....try taking out the console and looking at it from underneath. that noise from the e-brake is absolutely annoying...i also get a squeaking from the passenger side somewhere on a rough road. i get the clicking too....always when i push the clutch in
DJTR
228
OTTAWA, Ontario, Canada
May 11, 2004
  • May 11, 2004
With the Lighter I'm sure you have to remove the console to take it out.... I think its a push-in and there is a clip on the other side..... as for the clutch click, could be a sign there is a break in your clutch cable friends 92gt started doing that.... about 4 months later the cable grenaded...... not sure if that info will help but I figured I would throw it out there anyways
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 11, 2004
  • May 11, 2004
im thinking that clicking is just the neutral safety switch on the clutch quadrant. but i could be wrong
NosPony
278
Canton, Il
May 11, 2004
  • May 11, 2004
I had the e-brake rattle. I just turned the little button u push toward me (like it was a screw) mine stopped rattling. Give it a try might work.
I would say the plastic clutch quad breaking.(maybe?)
Hope this stuff helps.
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
May 11, 2004
  • May 11, 2004
Thanks for the input everyone.
I had the console off and couldn't figure it(lighter) out, thought maybe someone might have done it b4
Its not the neutral safety switch, I pushed it in/out independently(without depressing the clutch) and it was quiet.....seems like a bushing or something in the pivot assembly I was hopin' someone has disassembled theirs b4 and could give me some insight.
I put a BBK/Gripp adjustable cable/quadrant on it about 6 months ago. It has a stiff pressure plate ie pedal effort.....maybe previous owner put the HD FRPP set in it and the added stress has worn a bushing in the pedal assembly??
Thanks again for the responses.
SwAmPf0x
1,423
Hell Hole Swamp
May 11, 2004
  • May 11, 2004
on the lighter....there is an outer sleeve that screws on to hold it in place, cant really tell by looking at it but if you thread it off the lighter assembly will come out
PLEASE HELP! 99 Cobra Throwing Lean Codes and Stalling During Cold Starts
  • SVT_Aidan
  • Nov 22, 2021
  • SVT Tech Forum
SVT Tech Forum Jan 19, 2022
COramprat
Brakes 1979-1986 Fox Parking Brake Adjustment
  • LiquidStangs
  • Sep 22, 2019
10K
Fox 5.0 Mustang Tech Sep 23, 2019
LX Dave
D
Please help - mystery rubbing sound (it's not a wheel bearing assembly)
  • DannyJay
  • Jun 4, 2019
4K
2005 - 2014 S-197 Mustang -General/Talk- Jun 6, 2019
08GT500
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
C
Please Help 99 Mustang Not Starting
  • cody farmer
  • Apr 25, 2016
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 25, 2016
cody farmer
C
