please help!! c4 trans not working
  • Thread starter Thread starter looking4stang
  • Start date Start date Aug 19, 2004
L
looking4stang
108
  • Aug 19, 2004
ok i went to the track yesterday. before i went i had fluid in my tranny. i went to take my first run and i could not even complete it. 1,2, & 3rd are no longer their. it is a c4 competition tranny with about 1,000 miles on it. reveerse still works. i check the fluid and it was bone dry. could this have killed my converter? what went wrong with the trans internally? what would i need to repair the trans? what kit do you recomend? any help is appreciated.
L
looking4stang
108
  • Aug 20, 2004
anybody please?
L
looking4stang
108
  • Aug 21, 2004
TTT
J
jerry beach
2,671
Ocala,FL
Aug 21, 2004
  • Aug 21, 2004
You need to find out where the fluid went. Get under it, fluid should be all over the place. You may have to clean it up and fill the trans back up to find the leak. I cant see how it could have passed tech if it was leaking that badly. Anyway, once the leak is fixed and you re-fill it, being carefull not to overfill you will know if your trans is fried or not. It will prolly be OK. The C4 is pretty tough. I would go and get it flushed and changed again to be safe. There is likely some burnt fluid in there that needs to come out to ensure a long life.
L
looking4stang
108
  • Aug 21, 2004
thanks for your reply, i filled up the trans the same day. it still doenst work. what now?
J
jerry beach
2,671
Ocala,FL
Aug 21, 2004
  • Aug 21, 2004
Is it still leaking? Reverse works, but no forward gears? I am no trans tech, I would call around to some tranny shops and run it by them. Diagnosis of auto trans problem is not my thing. If it doesnt work, I check for obvious things and then out comes the trans and off to the shop it goes. Good luck to you. Maybe try calling to folks you bought it from first and see what they are willing to do for you. Also, who installed it? It is prolly their fault the fluid leaked out of it. that is what causes severe damage, running with no fluid.
J
Js5ohLX
287
Ohio
Aug 21, 2004
  • Aug 21, 2004
It's toast, time for a rebuild.
L
looking4stang
108
  • Aug 21, 2004
whats a rebuild go for?
dastang2
2,020
tx
Aug 21, 2004
  • Aug 21, 2004
i had something like that happen to me in a bronco 2. i just got it and knew it needed a rebuild because R did not work and it shifted a little hard and delayed. well that same day i was driving down the driveway in D and all of a sudden it jerked me forward and i started going backward with the shifter in D. it would not go forward now but only in R. the shop said it had to be totally junked. it had a cracked case they said. i really don't know what they did but it worked when i got it back and i loved the 4x4.
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
O
Help
  • OnisimusD
  • Oct 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 14, 2025
OnisimusD
O
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
