Please help!/ electrical
  • Thread starter Thread starter 91foxbod50
  • Start date Start date Sep 26, 2007
9
91foxbod50
486
  • Sep 26, 2007
Im haveing a lot of trouble getting through this disaster. Heres how it started. I started my car one day and it died out. I saw smoke comeing up from under the hood. I quickly jumped out and popped the hood up and saw that the wire was burnt out for the ecc. so the car wasnt getting fuel or spark. I replaced the wire with a fusible link but every time i start the car it burns out the fuse. I checked all of my connections and everything is solid. i went over the wire with a tester to see if their were any breaks in the line. I fallowed it back to the alternator. After i took the alternator off i saw that some wires were bent at an angle that looked as if it was causing the problem. I unbent them and reasembled everything and the car started right up. I took it for a testdrive around the block and it died right out on me. Im scratching my head and frustrated, it's a 91 mustang w/ a 95 motor and ive owned the car for 2 months.
88mouse
630
Mooresville nc
Sep 26, 2007
  • Sep 26, 2007
Recheck those wires again. That must be your probablem.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 27, 2007
  • Sep 27, 2007
Wires aren't just wires, they are color coded to help identify what they do. They have a main color and a color stripe. Without the color codes in your problem description, there is no way to tell what is the source of your problem.
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
9
91foxbod50
486
  • Sep 27, 2007
its a yellow wire off of the ignition, today i took the clip off the alternator to make sure it wasnt the alternator since it was getting very hot. It started up and then stalled out after i took off an let off the clutch. Theirfor i thought something was hitting the clutch and grounding something out. But i checked under the dash and everything was okay. It drives for a little before it blows the fuse
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 27, 2007
  • Sep 27, 2007
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer, actuator & sensor wiring
Fuse panel layout
Vacuum routing
9
91foxbod50
486
  • Sep 28, 2007
Just curious is the yellow wire off the starter relay a ground wire? I tested it w/ a pwr/ground test light, their was no power but it had ground. I also changed the fusible link w/ a straight power wire ( since it was constintly blowing fuse's) and it burnt up the wire.
HISSIN50
34
129
Sep 29, 2007
  • Sep 29, 2007
You might have a dead short in that circuit. This is why your test light tricks you into thinking that the wire is a ground wire.
AND PLEASE DON'T SCREW AROUND WITH REPLACING CIRCUIT PROTECTION DEVICES WITH WIRE. You need to track down that short and fix it, preferably without even reconnecting power to the circuit again. You will end up dissecting each branch of the circuit.
Good luck.
JBeezy53
559
Sacramento, Ca
Aug 30, 2008
  • Aug 30, 2008
What was the problem? Anyone else have this problem? My buddy's 93 GT is dong the same thing except the wire will immediately burn when the ignition is on and it is doing it after the fusible link.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 30, 2008
  • Aug 30, 2008
a repeat of my previous post is in order...
AutoZone.com | Vehicle Selection - Year for 79-88 model Mustangs
AutoZone.com | Vehicle Selection - Year for 89-93 model Mustangs
AutoZone.com | Vehicle Selection - Year for 94-98 model Mustangs
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
