Electrical Please help electrical
  • Thread starter Thread starter bolo413
  • Start date Start date Apr 25, 2021
bolo413
  • Apr 25, 2021
I have a 90 gt. When I start the car the turn signals come on solid, not very bright and the tach and gauges don’t work. While the car is running If I turn the key slightly to the start position again and hold it everything works and the turn signals go out. I have replace the ignition switch twice thinking I had a bad one. Can’t figure it out.
KRUISR
1,877
1,017
143
Apr 25, 2021
  • Apr 25, 2021
Turn signals on ... is this in the dash only or the front and rear lights as well.
If on the dash only, I would look at the cluster, the printed circuit, its grounds and connections.
bolo413
  • Apr 25, 2021
It is the front and rear lights also. When I turn the key a little bit to the start they go out and gauges work fine. But when I let it go back to the run position they come back on and gauges go out.
General karthief
Mod Dude
Aug 25, 2016
28,115
10,733
213
polk county florida
Apr 25, 2021
  • Apr 25, 2021
Did you replace the e!ectrical switch or the key switch?
bolo413
  • Apr 25, 2021
Ignition switch under steering column. Took switch off and engaged it with a screwdriver and it still does the same thing
General karthief
Mod Dude
Aug 25, 2016
28,115
10,733
213
polk county florida
Apr 25, 2021
  • Apr 25, 2021
Where did you get the switch? What brand?
bolo413
  • Apr 25, 2021
Got one from lmr and one from my local auto parts store.
General karthief
Mod Dude
Aug 25, 2016
28,115
10,733
213
polk county florida
Apr 25, 2021
  • Apr 25, 2021
Is the connector burnt, melted or discolored?
Fits tight?
bolo413
  • Apr 25, 2021
No nothing burnt no smell of burnt. Yes fits tight.
General karthief
Mod Dude
Aug 25, 2016
28,115
10,733
213
polk county florida
Apr 25, 2021
#10
  • Apr 25, 2021
  • #10
Not sure, from the description I'd say the electric switch but if you swapped in two new ones then I gotta tap out on this,
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,518
2,941
173
Florida
Apr 25, 2021
#11
  • Apr 25, 2021
  • #11
My experience is with older cars, but this sounds like a grounding problem to me
nickyb
I gotta say i never painted my nuts, Never Ever
3,039
1,666
163
nevada
Apr 25, 2021
#12
  • Apr 25, 2021
  • #12
You could try replacing the key switch, it maybe worn out.
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,953
5,831
213
Apr 26, 2021
#13
  • Apr 26, 2021
  • #13
Make sure you have the correct turn signal switch for the year car. Also check those wires. Unplug the turn signal switch and see if the gauges start to work. The turn signal switch should be interrupting any power to the lights. The printed circuit on the back of the cluster could also be causing the problem. I don't have a wiring diagram in front of me but power may be able to be back fed through the circuit from the indicator bulb circuit.
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
