2 2000GTKY New Member Feb 13, 2006 26 0 0 Feb 21, 2006 #1 Feb 21, 2006 #1 I used a SCT 2 on my mustang and now it wont start no i did not pull the fuse first and if a fuse is the ppm where is it located???
K Kilgore Trout Fried or Broiled ? 10 Year Member Mar 30, 2005 4,749 95 134 Feb 21, 2006 #2 Feb 21, 2006 #2 PPM? Is the theft light flashing? Have you tried resetting the PCM?
COramprat ...I can take it. I think. 20+ Year Stangneter Mar 2, 2003 8,474 1,463 223 Sea of Tranquility Feb 21, 2006 #3 Feb 21, 2006 #3 The only two fuses I know to pull are the fan and fuel pump. You must pull those before the flash.
2 2000GTKY New Member Feb 13, 2006 26 0 0 Feb 21, 2006 #4 Feb 21, 2006 #4 Where are those fuses located?
2 2000GTKY New Member Feb 13, 2006 26 0 0 Feb 21, 2006 #5 Feb 21, 2006 #5 PPM? Is the theft light flashing? Have you tried resetting the PCM? Yeah the light is flashing how do you reset the pcm and what is the PPM
K Kilgore Trout Fried or Broiled ? 10 Year Member Mar 30, 2005 4,749 95 134 Feb 21, 2006 #6 Feb 21, 2006 #6 2000GTKY said: Yeah the light is flashing how do you reset the pcm and what is the PPM Click to expand... Disconnect the battery and let it sit for 5-10 minutes. Then hook it back up and see if it starts. And I was asking you what you meant by PPM, you used the acronym in your post #1 in the thread..
2 2000GTKY New Member Feb 13, 2006 26 0 0 Feb 21, 2006 #7 Feb 21, 2006 #7 I meant problem sorry what is the PCM?
K Kilgore Trout Fried or Broiled ? 10 Year Member Mar 30, 2005 4,749 95 134 Feb 21, 2006 #8 Feb 21, 2006 #8 The PCM is the engine control unit. It is what makes the engine work.
