The wiring colors you spoke about are for a 91-93 Mustang.
Here's the fuel pump test path for those model years.
Fuel Pump Troubleshooting for 91-93 Mustangs
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for
5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump
the connector in the Upper RH corner to ground.
. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove
the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out,
catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware
of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under
the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you
have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92.
On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping
while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power path.
The control path consists of the computer, and the fuel pump relay coil. It turns the fuel pump
relay on or off under computer control. The switched power (red wire) from the ECC relay goes
to the relay coil and then from the relay coil to the computer (light blue\orange wire). The computer
provides the ground path to complete the circuit. This ground causes the relay coil to energize and
close the contacts for the power path. Keep in mind that you can have voltage to all the right places,
but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they
are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link
(pink/black wire) goes to the fuel pump relay contacts. When the contacts close because the relay
energizes, the power flows through the pink/black wire to the contacts and through the
dark green\yellow wire to the inertia switch. The other side of the inertia switch with the
brown\pink wire joins the pink/black wire that connects to the fuel pump. The fuel pump has a
black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays or injectors,
but provides the ground necessary to complete the circuit. That means one side of the circuit
will always be hot, and the other side will go to ground or below 1 volt as the computer
switches on that circuit.
diagram
of the wiring for 91-93 cars.
Now that you have the theory of how it works, it’s time to go digging.
Power circuits:
Power feed: Look for 12 volts at the pink/black wire (power source for fuel pump relay).
No voltage or low voltage, bad fuse link, bad wiring, or connections. Remember that on
92 or later models the fuel pump relay is located under the Mass Air meter. Watch out for
the WOT A/C control relay on these cars, as it is located in the same place and can easily
be mistaken for the fuel pump relay.
Relay: Turn on the key and jumper the ECC test connector as previously described. Look
for 12 volts at the dark green\yellow wire (relay controlled power for the fuel pump).
No voltage there means that the relay has failed, or there is a broken wire in the relay control circuit.
Inertia switch: Check the brown/pink wire, it should have 12 volts. No 12 volts there,
either the inertia switch is open or has no power to it. Check both sides of the inertia switch:
there should be power on the dark green\yellow (inertia switch input) and brown/pink wire
(inertia switch output). Power on the dark green\yellow wire and not on the brown/pink wire
means the inertia switch is open. Press on the red plunger to reset it to the closed position.
Sometimes the inertia switch will be intermittent or will not pass full power. Be sure that
there is 12 volts on both sides of the switch with the pump running and that the voltage
drop measured across the switch is less than .75 volts.
Control circuits:
Relay: The red wire for the fuel pump relay coil gets its power feed from the ECC relay.
No 12 volts here, and the ECC relay has failed or there is bad wiring or bad connections coming from it.
The ECC relay is located on top of the computer, which is under the passenger’s side kick panel.
It is not easy to get to, you must have small hands or pull the passenger side dash speaker out to access it.
Relay: The light blue/orange wire provides a ground path for the relay power. With the test connector
jumpered according to the previous instructions, there should be less than .75 volts. Use a test lamp
with one side connected to battery power and the other side to the light blue/orange wire on the fuel
pump relay. The test light should glow brightly. No glow and you have a broken wire or bad
connection between the test connector and the relay. To test the wiring from the computer, remove
the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that
holds it in place. Remove the test jumper from the ECC test connector. With the test lamp
connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the
wiring between the computer and the fuel pump relay is bad.
Computer: If you got this far and everything else checked out good, the computer is suspect.
Remove the test jumper from the ECC test connector located under the hood . Remove the plastic
cover over the computer wiring, but leave the computer wiring connector plugged into the computer.
With the ignition switch in the run position, connect a test lamp to the battery and back probe pin 22,
the light blue/orange wire with it. The lamp should glow brightly. No glow and the computer
has died a sad death.
If you used a voltmeter instead of a test lamp, you should see battery
voltage, whatever that may be…
Fuel pump runs continuously: The light blue/orange wire has shorted to ground. Disconnect the
computer and use an ohmmeter to check out the resistance between the light blue/orange wire
and ground. You should see more than 10 K Ohms (10,000 ohms) or an infinite open circuit.
Be sure that the test connector isn’t jumpered to ground.
