please help - hot/cold climate controls don't work, only blows hot air
Sep 3, 2018
14
Johns Creek, GA
Hi gang, I've searched google and this forum and can't find any guidance so far. No matter whether I set my climate control to blow hot or cold air, it only blows very hot air out of all vents.
A little history (of course I get myself into these situations)
I had the common problem of the 1,2,3,4 fan speed setting being stuck on a single setting, in my case at 4.
I diagnosed the blower fan resistor INCORRECTLY as a climate control panel problem, and replaced the climate control panel with one that was supposed to be a replacement for my 2008 Mustang. Fun thing happened when the replacement arrived - I noticed the 2 electrical connectors on the back of the climate control panel were rotated differently and the assembly was a different method, HOWEVER the 2 electrical connectors fit just fine. Had the same problem, fan still worked on setting 4 with no changes in speed on the control. At that point I went to research correctly, and replaced the resistor.
NOW all the fan speeds worked, but the AC would not turn on.
So then I put the original panel back in. Now everything appears to work fine EXCEPT all I get is hot air.
Any hope or ideas for me? THANKS GANG!
  • Sponsors(?)
Bullitt95
1,561
61
79
Cyprus
www.angelfire.com
Sounds like the compressor is operating normally. If you check the lines after a few minutes of operation, you should find one side to be almost icy cold. If that's the case and you're still getting only warm air from the dash vents, it's possible one of the blend door actuators is stuck.
Sep 3, 2018
14
Johns Creek, GA
Thank you Bullitt95. This appears to be resolved.
Yesterday I took the climate panel back out, hit all the connections with electrical contact cleaner and re-installed it and magically I have heat and cool controls with full functioning AC / climate control. It appears a connection in the back of the climate control panel that manages heat/cold setting wasn't making contact. There were no bent pins.
Thread starter Similar threads Forum Replies Date
M Electrical HELP PLEASE! A/C Blowing hot air! 2005 - 2014 Specific V6 Tech 2
B HELP PLEASE- Ac blowing hot air. SN95 4.6L Mustang Tech 3
lawd..hammercy Engine 2005 GT Running Hot After 30 Mins of Driving. Please help! 2005 - 2009 Specific Tech 12
M Please Help: 2013 3.7L is Hot (AC Issue?) 2005 - 2014 S-197 Mustang -General/Talk- 4
C Please Help Running Very Hot Fox 5.0 Mustang Tech 19
S Need Help Bad Please !! 1996 - 2004 SN95 Mustang -General/Talk- 8
H car dies out wen it gets hot PLEASE HELP!!!! Fox 5.0 Mustang Tech 8
B car won't start when hot... help please??? Fox 5.0 Mustang Tech 6
aod92 CAR GETTING HOT!!! PLEASE HELP Fox 5.0 Mustang Tech 3
H Please HELP...it's hot warm outside and my windows won't go down! Fox 5.0 Mustang Tech 33
B Every time my 5.0 get hot, I have no power...at all, please HELP!!! Fox 5.0 Mustang Tech 12
O 97 COBRA: +WIRE get hot,sliggght knock and will not idle under 1k, please help!!!!!!! SN95 4.6L Mustang Tech 0
Saleen8786 engine getting really hot (HELP!!!!)please 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Killer50stang Running Hot!!! Why? Please help! Fox 5.0 Mustang Tech 25
OrangeMustangGt help! clicking sound when engine gets hot: please throw some info in here. 1994 - 1995 Specific Tech 4
silverlx50 Engine Help with jrichker's injector testing, more details please Fox 5.0 Mustang Tech 0
R Please Help! Ideas/Tips on how to make my '93 2.3l (NA) Convertible Faster. 2.3L (N/A & Turbo) Tech 6
D Need sct x4 users help please. Digital Self-tuning Forum 0
B 1994 mustang cooling fan wiring? PLEASE HELP!! 1994 - 1995 Specific Tech 0
sams93gt Engine Valvetrain help please!! Fox 5.0 Mustang Tech 8
markinms Engine surges, cutouts, rough running during acceleration - Help Please! Fox 5.0 Mustang Tech 5
J Please help - 68 Convertible J-Code confirmation/value 1965 - 1973 Classic Mustangs -General/Talk- 1
K Please Help!! Shifting from 1st to 2nd 2015+ (S550) Mustang -General/Talk 1
M 93 fox body 5.0 with no power going to 20 amp circuit breaker at fuse box. HELP PLEASE!! Fox 5.0 Mustang Tech 1
R Help please Digital Self-tuning Forum 0
L Please Help 2013 GT 5.0 The Welcome Wagon 0
M Please help 1989 GT Hatchback.I can not find an L.E.D.smoked 3rd taillight. The Welcome Wagon 4
J Please help '93 mustang The Welcome Wagon 1
9 MegaSquirtPNP 2 problems please help. Digital Self-tuning Forum 12
D 1995 mustang gt 5.0 Need help please! 1994 - 1995 Specific Tech 8
D please help fuel pressure issue 1996 - 2004 SN95 Mustang -General/Talk- 0
B Help please. wiring for alternator upgrade 2010 - 2014 Specific Tech 5
B "Please help" 95 v6 5speed - v8 carb swap The Welcome Wagon 3
A Please help I can't find bushings 2005 - 2014 S-197 Mustang -General/Talk- 4
1 Engine NEED HELP PLEASE!! Fox 5.0 Mustang Tech 4
M Help please new mustang owner 2005 - 2014 S-197 Mustang -General/Talk- 2
G Hey everyone, I'm new here, please help a girl out with some advice! Sell or restore? 1996 - 2004 SN95 Mustang -General/Talk- 58
R Help please. Burns oil, low compression but no broken rings. SN95 4.6L Mustang Tech 1
Lake Martin John VIN help please. 1965 - 1973 Classic Mustangs -General/Talk- 20
D Please help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
L I'm New, Need help. please. SN95 V6 Mustang Tech 1
L Please help 2.3L (N/A & Turbo) Tech 11
S PLEASE HELP 1996 - 2004 SN95 Mustang -General/Talk- 1
J Paint and Body Quarter window weatherstrip help please 1996 - 2004 SN95 Mustang -General/Talk- 1
D Fuel Starts W/ Fluid. Torque App Shows No Fuel Pressure at Rail. Help Please SN95 4.6L Mustang Tech 10
T Please help, a noob needs help with another exhaust question! 2005 - 2014 S-197 Mustang -General/Talk- 5
M Please help need weatherstrip that fastens to interior quarter panel 1965 - 1973 Classic Mustangs -General/Talk- 0
C Just got a 1990 lx notchback. I need help please 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
J "Please Help" The Welcome Wagon 2
4 Please help my PCM is flooding my engine Fox 5.0 Mustang Tech 11
