Just installed the Accufab Plenum and I having a couple of new problems and some older problems are worse.
After completion i got in the car and the gas pedal was in the wrong damn place...my only guess is that i pulled on some throttle cables while i was moving the throttle body out of the way. So i was able to step on the gas and get it back into place so fixed that myself.
Next problem is my old idle problem is still sticking around. The car idles poorly (too high mostly) and when i drive it the rpm hangs up over 2000 most of the time. Its worse now that I put the new plenum in. I just replaced the IAC last week and the idle problem hasn't gone away.
Also the check engine light is back on now, I added the Mil Eliminators a month or so ago and thought i fixed that.
Any ideas, i reset the computer (i'm trying that again now too)...The idle was really bad when i got in the car (when the gas pedal was out of place) the car idled at 2500 and the pedal was about an inch closer to me utill i pushed it back. Now it idles up over a 1000 and hangs almost every time i touch the gas. In fact i was driving and the car was accelerating a little while i wasnt touching the gas...Sounds like a throttle cable problem or something...not sure any help would be great.
The relevant setup is...
1997 GT
Mac 70mm TB
Accufab Plenum
New IAC
Mac Cold Air Intake
1997 GT
Mac 70mm TB
Accufab Plenum
New IAC
Mac Cold Air Intake
