Please help - Long. Car Troubles
NitroNixon
67
D.C. Baby
Yesterday, I was drive home, car was running fine when all of a sudden my car starts to sputter really bad and eventually stall. I tried to restart the engine with no luck. It seemed like the engine wasn't getting enough fuel to start and stay running.
I let the car sit for 30 minutes and tried to restart the engine but this time the car would run for 2-4 seconds then stall. Next, I tried to prime the fuel system by turning the key on and off several time before starting the engine and it worked. The engine ran for about 30-45 seconds before it stalled only this time I watched my fuel pressure gauge while the engine was running and the pressure slowly dropped from 33lbs to 5lbs before it stalled.
I let the car sit for another ten minutes and reprimed to fuel system again before starting. This time I was able to drive the car for 15-20 minutes before it stalled again. I barely made it home that time.
Can someone explain this to me? Any recommendations on what to check? I'm beginning to think that it's my fuel pump going bad.
Yeah,
That's what I'm guessing, but I won't be able to install it until the weekend. I hope this clears the problem.
If a fuel pump goes bad, wouldn't it just stop working all together instead of working half the time?
NitroNixon said:
Yeah,
Not necessarily...especially an electric fuel pump. I've even had mechanical pumps do that.
Replace the fuel filter first and if that doesn't fix, replace the fuel pump. Anytime you replace the pump, it is a good idea to replace the fuel filter.
