- Nov 29, 2004
- 75
- 2
- 6
I recently built and installed a built PI 2v for my 96 GT Coupe and now I am having some noises that I am not exactly sure what it is, my first thought was piston slap, but i removed each spark plag wire 1 at a time and the noise did not change at all, so any help you guys can give would be greatly appreciated, any chance it could be the oil filter? I heard something about that possibly making noise. It almost sounds like it has a cam in it (which it doesnt), but i paid very close attention to making sure the timing was right, it drives smoothly, I havent done any WOT runs or anything until i get the sound diagnosed. It is a constant tick that never goes away except I cant seem to hear it above 2000 due to the exhaust. Its loudest near the underside of the drivers side door. Here is what I have it narrowed down to:
1 Piston Slap - Pulled each plug wire 1 at a time and the noise did not change at all. The internals were balanced by livernois motorsports and the block was prepped for the internals. (I dont think this is it)
2 Spun Bearing - Doesnt sound like other spun bearings I have heard, not really sure how to test for it, engine maybe has 45 mins to an hour of run time.
3 Oil Filter - Not sure if that could even be a reason but I think I read something about it somewhere.
4 Exhaust Leak - Again not sure how to check for it but could be a possibility
Well sorry for the long post and thanks for any help I get
video 1 http://www.youtube.com/watch?v=W4WIMOlsbLE
video 2 http://www.youtube.com/watch?v=uRC6PBHHHwQ
video 3 http://www.youtube.com/watch?v=vOOL5pIy3BY
Edit: Engine keeps throwing P1445 code which means Purge Flow Sensor Circuit High Input, Im not sure what that means.
. Anyway, just drive it like a grandma until you find out what that noise is. Good luck.
