Please help on compressor decision
  • Thread starter Thread starter jb1dsl
  • Start date Start date Sep 9, 2006
  • 3
First Prev 3 of 3
jb1dsl
566
Marianna, Fl.
Sep 14, 2006
#41
  • Sep 14, 2006
  • #41
It has a 4 wire plug, That is why i'm wondering about the extra wire?
Jester67
908
TN
Sep 14, 2006
#42
  • Sep 14, 2006
  • #42
It is a ground / "earth"
Jester67
908
TN
Sep 14, 2006
#43
  • Sep 14, 2006
  • #43
Black/red hot
white netural
green ground " sometimes it is not green but it is a ground"
jb1dsl
566
Marianna, Fl.
Sep 14, 2006
#44
  • Sep 14, 2006
  • #44
How would I tie to the compressor since it only calls for 3 wires, the black/white and ground. The black hookup to the line side of pressure switch. No mention of red???
Jester67
908
TN
Sep 14, 2006
#45
  • Sep 14, 2006
  • #45
black/white ground is 120v not 220v
V
vintage dave
#46
  • Sep 14, 2006
  • #46
I am an electrician. The black and red are the hots. The white is the nuetral. The bare wire is the ground. You need 10-2 wire if you use romex for the cord and you use the black and white for the hots. If you use an extension cord or SJO cord, you need 10-3, as it is rated by the number of wires in it.
SJO cord is a heavy duty, very flexible cord that can take a lot of abuse.
By the way, so you know, #12 wire is rated for 20 amps, #10 for 30 amps.
Anymore questions, let me know. Also, they are right, you can never have too much compressor. I have an 8.5hp, 80 gallon campbell hausefield.
jb1dsl
566
Marianna, Fl.
Sep 14, 2006
#47
  • Sep 14, 2006
  • #47
A SJO cord sounds like the way to go because it is tough and flexible. I will get 10/3 sjo.
jb1dsl
566
Marianna, Fl.
Sep 14, 2006
#48
  • Sep 14, 2006
  • #48
dave you have a pm
jb1dsl
566
Marianna, Fl.
Sep 15, 2006
#49
  • Sep 15, 2006
  • #49
So how does it need to be hooked up? 4 wires, 3 wires, whicn wires and where? On the compressor and the plug?
V
vintage dave
#50
  • Sep 15, 2006
  • #50
You will also need to buy a male cord cap for the cord. It is a cord end with no wires leaving it. Take the cap apart . The black and white wires will be your hots.
They will connect to the two straight blade terminals on the cord cap. The rounded terminal is your ground. The green wire will go there. Typically, the screw head where the ground goes is green and where the hots go is gold in the cord cap. Where the white would go if you were using it is a silver screw head. You can take your dryer plug out to verify it is connected like this. You will not use the nuetral terminal. In the pressure switch, you will need a connector for the cord (you can use a romex connector that has a threaded end ). According to the link you provided, the to hots will connect to the line side of the pressure switch. One wire on each terminal. More than likely, there is a green screw that the green wire will go to. Depending on how it is in the compressor, there may be a lug to connect the to. But also, you could need a yellow fork or round end crimp stake on for the green wire. I hope this helps.
jb1dsl
566
Marianna, Fl.
Sep 16, 2006
#51
  • Sep 16, 2006
  • #51
Well I picked it up today..I got the one from lowes. I took the sheet on the husky from home depot(hundred dollars cheaper) and they price matched it..The kobalt has better cfm ratings. I also picked 10/3 sjo and have teh plug hooked up. I just got to get a few friends to help me unload it!!! Thanks for all the help and advice!!
jb1dsl
566
Marianna, Fl.
Sep 16, 2006
#52
  • Sep 16, 2006
  • #52
I got the larger of the two from lowes (13.3 cfm @ 90,15.2cfm @40)
Jester67
908
TN
Sep 17, 2006
#53
  • Sep 17, 2006
  • #53
good choice
67efivert
348
lincolnton nc
Sep 17, 2006
#54
  • Sep 17, 2006
  • #54
did u get all of the wiring figured out if not pm me i will explain it all to u iv dont this many times
jb1dsl
566
Marianna, Fl.
Sep 17, 2006
#55
  • Sep 17, 2006
  • #55
Yeah I got help from vintage dave (THANKS!!). He gave me a good walkthrough. I got 10/3 sjc cord and a 4 prong plug and hooked it up to the dryer outlet. Thanks again
  • 3
First Prev 3 of 3
got to buy a compressor - need your advice pls
  • stangman16
  • May 27, 2009
3K
Classic Mustang Specific Tech May 28, 2009
ultrastang
Body/Paint Experts, Please Help
  • horseballz
  • Apr 26, 2010
Classic Mustang Specific Tech Apr 26, 2010
2+2GT
I'm in deep shi*t... blew it up.
  • EL1NOR
  • Nov 19, 2004
Classic Mustang Specific Tech Nov 20, 2004
WORTH
While were on welders....
  • 1973mach1
  • Sep 1, 2004
Classic Mustang Specific Tech Sep 2, 2004
emeraldcoupe
E
Spider Webs in the paint!!!
  • mo_dingo
  • Sep 10, 2004
  • Mustang Sound & Shine All
Mustang Sound & Shine All Sep 13, 2004
mo_dingo
