Please help quick!!!!!
I recently did a head, injector, intake, tb, mass air , cam install. I cant seem to get the car to turn over. It has fuel, the timing seems right. I have it set at TDC with the cap at 1. I have fuel and spark. The plugs seem a little dark just from cranking it. I also have a adj. fuel pres. reg. what should the pressure be on start up. Also, if I have the key in the on position and I turn the distributor it sounds like its kicking the fuel pump on and off. Does this seem normal???? Someone please help!!!!!!!!!!! IM CONFUSED!!!!
I moved the balancer so that the timing was set on 10* BTDC. Stabbed the dizzy at 1 and still nothing. It doesnt back fire which makes me think the timing isnt that far out. The plugs look dark, could it just be flooded? Are the pugs fouled out? I wonder if its something in the ignition, like the coil cap or rotor. But it should still start.....
i think you have the same problem i have. i put my motor together and abviously my pushrods were to long so i needed shims to let the valve close all the way. i think since you just put a bunch of new stuff on, your valve geometry is out of wack causing a no run situation. do a compression test and are your rockers a little loose when the valves are closed. they should be.
You could be off (timing too retarded) in the dizzy, put the damper TDC and make sure it is pointing to #1 spark w/TFI module pointing to the 4:30 clock position (looking at it from the top), if not...install it that way, this will give you enough space to advance the distributor w/out having interference problems with the TFI module connector. LUK
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Thanks guys. I went through the checklist and found a few things.
#1 moisture in the cap
#2 Plugs fouled out, weak spark
#3 when I pulled the plugs and cranked the motor manually I had a bunch of fuel spill out through the plug hole which makes me think it was flooded.
#4 when I installed the cam, I installed it 2* advanced so I have to take out a little timing
#5 Battery doesnt have full cranking power
I went over the valves multiple times. Re-doing the roller rockers to a T. I used the pushrods that Trickflow has in their specs for the Twisted wedge heads. I also replaced the lifters.
So, Im going to try and fix all of this and try again.
The question to answer on #3 would be, how did that excess fuel got in there?...make sure the FP regulator is not leaking fuel through the vacuum line (perforated diaphragm).
Regarding #4, cam and ignition timing are two separate things...you can go with 10°, 12° or 14° BTDC with no problems. LUK and GL.
