  • SN95 4.6L Mustang Tech
Please help troubleshoot my problem.
  • Thread starter Thread starter tanion
  • Start date Start date Jun 9, 2005
  • 3
1 of 3 Next Last
tanion
230
Charlottesville, VA
Jun 9, 2005
  • Jun 9, 2005
I have a 2001 GT automatic with 47K miles. Only engine mods are a K&N intake kit and steeda underdrive pulleys which have been on for a long while. The problem is that the car often jolts while cruising along. It's most noticeable when trying to just maintain a low speed, holding it between 1000 and 1500 RPM. It's been doing this for quite some time. However, it seems to be getting progressively worse. I now can sometimes feel this jolting while accelerating although it's much less noticeable when I'm on the gas. The car is past due for a fuel filter replacement as prescribed by the recommended maintenance schedule. I plan to check the MAF to see if there is possible some oil from the K&N causing problems. Any suggestions will be greatly appreciated.
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
Jun 9, 2005
  • Jun 9, 2005
I would bet it's the MAF. Especially at low speeds at the rpm you specified. When did you oil the K&N?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 9, 2005
  • Jun 9, 2005
Could be MAF. Could also be tranny related. Have you even changed the fluid and filter?
tanion
230
Charlottesville, VA
Jun 9, 2005
  • Jun 9, 2005
It's been about 3 or 4 months since I last cleaned and oiled the air filter. So checking the MAF will be my next option. When I first noticed this happening the first thing I did was have the tranny fluid changed since it was overdue anyway but that did not help. I've tried resetting the computer by disconnecting the battery for a few minutes but that did not help either. As I said earlier, the fuel filter is overdue to be changed but I don't know if that is the problem. The sensation when it happens is kind of hard to describe. Like brief pulses of hesitation, it's definitely become more noticeable over the past few weeks.
Jackie Chan
I didn't read this.
2,507
Orlando, FL
Jun 9, 2005
  • Jun 9, 2005
could be the ac kicking on and off
MineralG2k2GT
451
Lowell, MA
Jun 9, 2005
  • Jun 9, 2005
It very well could be the MAF..when i cleaned my K&N i used the recharger kit and definitly put to much oil on the filter..it got all over the MAF and my car ran like ass as a result. Once I took it off and cleaned it with some car cleaner it ran great again
tanion
230
Charlottesville, VA
Jun 9, 2005
  • Jun 9, 2005
No, it's definitely not the AC.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 9, 2005
  • Jun 9, 2005
If you cleaned the K&N 3-4 months ago it is defintely the MAF.
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
Jun 9, 2005
  • Jun 9, 2005
Cleaning the MAF
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
Jun 9, 2005
#10
  • Jun 9, 2005
  • #10
wtf, damn double posts...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 9, 2005
#11
  • Jun 9, 2005
  • #11
Step by step with pictures:
http://www.bullittarchive.com/html/modules/articles/article.php?id=77
tanion
230
Charlottesville, VA
Jun 9, 2005
#12
  • Jun 9, 2005
  • #12
Thanks for the pictures. Hopefully cleaning the MAF will work because right now the car is running like crap.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 9, 2005
#13
  • Jun 9, 2005
  • #13
I am starting to think paper filters > K&N
C
chimchim
267
PA
Jun 9, 2005
#14
  • Jun 9, 2005
  • #14
When you say "past due" on that fuel filter, do you mean it's never been changed in 47,000 miles? If so, change it. For like 10 bucks and twenty minutes, it's worth a try. I had an S-10 truck with 80,000 miles and I never changed the fuel filter. It got so bad that it felt like turning the ignition on and off. Anyway, after I changed it the truck ran better than it had in YEARS. From just the fuel filter. Try the cheapest stuff first.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 9, 2005
#15
  • Jun 9, 2005
  • #15
Step by step fuel filter change with pics:
http://www.bullittarchive.com/html/modules/articles/article.php?id=73
R
Red2000GT
2,450
Regina,Sask.Canada
Jun 9, 2005
#16
  • Jun 9, 2005
  • #16
A bad oxygen sensor will cause that problem too.
M
MidnightBlk98GT
45
FL
Jun 9, 2005
#17
  • Jun 9, 2005
  • #17
But that would trigger something in the computer and the CHECK ENGINE light would come on even if it's just a split second hesitation. If the the upstream sensors had a problem, you'd probablly notice instantly but maybe not so with the downstream sensors.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 9, 2005
#18
  • Jun 9, 2005
  • #18
It is the MAF, it has oil on it from the filter.
tanion
230
Charlottesville, VA
Jun 10, 2005
#19
  • Jun 10, 2005
  • #19
Thanks for all the suggestions and pictures. I'll be cleaning the MAF and changing the fuel filter this weekend. By Monday hopefully everything will be fine. I must admit I've been kind of neglecting my stang a little since I started riding motorcycles a couple years ago. Time to show the stang more tlc.
GTron
86
Fairfield, TX
Jun 10, 2005
#20
  • Jun 10, 2005
  • #20
Sounds exactly like the problem I've been having. If it is, it will progressively get worse and worse. Mine's to the point that when the A/C is running, I can't get up to 30 mph. I've tried cleaning the MAF, new plugs, fuel filter all kinds of stuff. Now, I'm just waiting on my Xcal II so that I can datalog the computer and send the info off to be analyzed. Nobody has had an answer on this.
  • 3
1 of 3 Next Last
  • Gulftown980x
  • Jul 29, 2026
squeak93
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
A
Looking for Help to Fix My Dad’s 96 Mustang GT Convertible in Central Florida
  • Auspicious Angmo
  • Oct 28, 2024
  • The Welcome Wagon
The Welcome Wagon Oct 28, 2024
89ripper
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
T
Newbie here with an odd story
  • thequadfather
  • Jul 20, 2024
  • The Welcome Wagon
The Welcome Wagon Jul 22, 2024
thequadfather
T
