please help with ac
Apr 28, 2003
36
im trying to get my ac working, im not getting power to the switch on the compressor, when i jump the two terminals on the compressor it kicks right on and the air blows cold but it obviously wont cycle, is there any relays i should check, also i checked and there is power to the ac fuse, and there is also power to the switch on the reciever dryer, thanks for any help you can give
black87gtbeauty said:
im trying to get my ac working, im not getting power to the switch on the compressor, when i jump the two terminals on the compressor it kicks right on and the air blows cold but it obviously wont cycle, is there any relays i should check, also i checked and there is power to the ac fuse, and there is also power to the switch on the receiver dryer, thanks for any help you can give
OOOPS - I misread this one...
Have any of you guys (or anyone out there) used any of the alternatives? I heard of one called Hot Shot some time ago and it was relatively cheap. I just did a little research and it is listed on the EPA site :
http://www.epa.gov/ozone/snap/refrigerants/lists/mvacs.html
I'm going to see if I can find more info about it. From what I remember, it was compatible with the R12.
Also, jrichker, is the fact that your A/C isn't as cold due to the less effective refrigerant (R12 vs. R134a) or the differences in the equipment, if any, from an R12 to R134a system (i.e. Pressure).
Thanks!
Edit: I just found a price and they are around $16/10 oz. can
- Jeff
Going backwards from the AC clutch would be the WOT relay (the most likely spot to have an electrical issue IMHO). Look for vulcanized wiring or a bad relay (heat really wipes both out). The relay and socket are on the pass fender adjacent the air inlet tube and the front of the strut tower.
You already checked the LPS, which would be the next step backwards from there.
Some manifold gauges to see pressures (if you have gauges) would be a nice thing to use.
Good luck.
thanks for your quick replies guys, the whole system has been converted to r 134a before i baught the car, it has the red and blue dust caps and the reciever dryer is brand new as well as the compressor, i hooked up the gauges and i got a reading of about 30 on the low side and about 250 on the high side, but due to the fact that the compressor is not cycling i dont think im getting correct readings, im gonna replace the relay on the pass inner fender, if thats not it what would be the next thing to try
thanks
