Please help with Modifications!
A 70-76mm will be fine. Some like C&Ls, some like ProM, which went out of business. You can still find used ones on ebay, though. They're supposedly just under a differnt name. Pro Mass Air Systems I think. I don't know if they carry the same sizes as they used to. But like I said earlier, 70-76mm. I would get gears before anything. Also I forgot to mention subframe connectors. If you get gears, make these the next modification after.
Have the subframe connectors welded in with all four tires on the ground or bearing the weight of the car. The full lenth cover a larger portion of the subframe giving it more contact area with it to make the chassis more rigid. If you are on a budget. Remove the air silencer on your air filter and put a K&N air panel in there. Forget about the Cold Air Intakes unless you are trying to clean up the engine bay. They really don't have any gains over the stock setup with a K&N. Rear gears will help a lot too. If this is a daly driver, I suggest 3.55 for a 5 speed and 3.73 for an auto. The FMS brand of gears are hard to beat so stick with those. One of the bigger bottlenecks on the 5.0s is the intake. I suggest getting your stock one ported by tmoss or buying a GT40/Cobra or Edelbrock. This will give you more power without sacrificing your low end. If you are on a budget PM tmoss or here's his website. http://www.tmossporting.com/ . Then you should think about the MAF and throttlebody.
Kevin
The stock headers are fine. You won't really see any improvement untill you hit the 300 HP mark. UD pullies can help. It is either hit or miss wheather your engine will respond to them well. You can run into cooling issues or charging issues... or both. Either way definately get one of the "street" sets.
Kevin
savegoodautonfg said:
Where can i find the air silence and what do you mean by a K and N air panel?
You don't need to worry about it. Your cold air intake fixed this. The silencer is this plastic piece that pops out of the airbox surrounding the filter that makes up half of the box. A K&N air panel is just a highflow box-shaped (like the factory one) air filter.
What does porting your head do?
If you arent scared to spend some money, your best bet would be buying some aluminum heads for $1000-1300. Great upgrade, loads of horsepower, and loosing some weight off that front end. Popular heads on here are AFR or Trickflow, some Edelbrock.
I want to get a TB and A MAF next. Considering my engine is mostly stock what should i get like brand and mm's. Please reply. Thanks again.
As for TB, I have heard nothing but good things from accufab. I have a bbk and like it and had no problems. Depending on if you are keeping your engine mostly stock go with 65mm. If you are going to upgrade your heads and cam go with 70mm. Some people will say 70mm will hurt your performance on stock engine but i beg to differ since I have 70mm with my stock head cam.
And for MAF, look a couple posts back, Intenseblue covered that.
First what is your overall (end goal) for the car? I know that we all want to make them as fast as possible while we upgrade but understanding if you want a S/C, Turbo, Nitrous or Naturally Aspirated?
TB brands have been mentioned already: Stick with a 65mm unit for now is my recommendation
Accufab
BBK
Holley (?)
the 65mm unit off a Explorer 5.0L (TMOSS has the write up for installing it)
The MAF suppliers have also been mentioned already: The reason I asked about your plans come into play right here. If you buy one for the stock setup you will have to replace it or have it recalibrated for larger injectors the further you move away from a stock setup: I go with a 73mm C&L or similar for now (you can alway's resale them on eBay as you change things)
C&L
The new Pro-M site (Daggar has the link in his sig)
